Conceptual Aspect of Relativity: Electric & Magnetic Forces
  • Context: Graduate
  • Thread starter Thread starter Ja4Coltrane
The discussion focuses on the conceptual aspects of relativity concerning electric and magnetic forces in a system with moving charges. It highlights a scenario where positive charges move to the right and negative charges to the left, questioning the effects of length contraction on the forces experienced by a positive charge placed above the wire. The conclusion emphasizes that both electric and magnetic fields exist in frames comoving with either charge type, and it is essential to calculate the total force and understand how forces transform under special relativity to resolve the apparent contradictions.
  • Understanding of special relativity principles
  • Knowledge of electric and magnetic field interactions
  • Familiarity with Lorentz transformations
  • Basic concepts of force transformation in relativistic contexts
  • Study the transformation of electric and magnetic fields under Lorentz transformations
  • Learn about covariant transformations of forces in special relativity
  • Explore the concept of electromagnetic field tensors
  • Investigate scenarios involving length contraction and its implications on charge interactions
Physics students, educators, and researchers interested in the fundamental principles of electromagnetism and relativity, particularly those exploring the interactions of moving charges and the transformation of forces.
Ja4Coltrane
I am giving a little lecture on the conceptual aspect of relativity tomorrow and was wondering something.
Consider a wire carying positive charges moving to the right and negative charges moving to the left. Say that a positive charge is placed above the wire and this positive charge moves at the some velocity as the positive charges within the wire.
Now I know that what happens is from the frame of the negative charges there is a magnetic force and from the frame of the positive charges there is an electric force due to length contraction acting on the free positive charge but my question is this: why doesn't length also contract for the frame of the negative charges? It seems to me that the positive charges should contract and therefore create an electric force which opposes the magnetic force. Does it have something to due with the fact that the charge on top is moving too? Any help is GREATLY appreciated.
You should, in general, expect there to be exacty one frame in which the electric field is zero.
In your example, you are assuming that this is a frame where the positive charges are moving right and the negative charges are left.
Therefore you are correct in thinking that there will be electric fields in both a frame comoving with the positive charges and a frame comoving with the negative charges.
What you probably want to do is therefore work out the total force (electric and magnetic) and show that it transforms covariantly.
To do that, one of the things you need to know how forces should transform under special relativity. I'm assuming that you do know this or that at least it would do you some good to think about it. If you don't know or get stuck, ask some more questions.
  • · Replies 20 ·
  • · Replies 55 ·
  • · Replies 34 ·
  • · Replies 27 ·
  • · Replies 24 ·
