Density of Gliese 581 d: What's the Real Number?
  • Context: Undergrad
  • Thread starter Thread starter DaveC426913
    Density
The density of Gliese 581 d is under scrutiny due to conflicting estimates regarding its radius and mass. According to available data, Gliese 581 d has a radius approximately 1.96 times that of Earth and a mass about 7.7 times greater, which suggests a density similar to Earth's. However, the reported density of 730 kg/m³ (0.73 g/cm³) raises questions, as it is significantly lower than expected and comparable to that of Saturn. The lack of citations in the sources further complicates the reliability of these figures.
  • Understanding of planetary density calculations
  • Familiarity with mass and volume relationships
  • Knowledge of celestial body measurements
  • Basic grasp of astrophysical terminology
  • Research authoritative sources on exoplanet density measurements
  • Explore the methods for calculating planetary density using mass and volume
  • Investigate the characteristics of Gliese 581 system and its planets
  • Learn about the implications of density variations in celestial bodies
Astronomers, astrophysicists, and students interested in exoplanet research and density estimation methodologies.
DaveC426913
2025 Award
I'm trying to find a reasonable estimate of the density of Gliese 581 d (not c).
According to Wiki, d is ~1.96x the radius of Earth and ~7.7x the mass. This makes for a density very near Earth's (2^3=8). Yet they then go on to list its density as 730kg/m^3 or 0.73g/cm^3 - almost as rarefied as Saturn.
Can anyone point me at some more authoritative numbers? I know we're only estimating, but clearly one of those three numbers r,d or m is spurious.
Astronomy news on Phys.org
They all could be right due to a few things. When you calculate the density via M/V you are basically assuming a constant density throughout the entire planet, but usually that is a decent for a very rough approximation.
I notice the article you mention is lacking citations on both the radius and the density, so it is possible those are flawed as well.
  • · Replies 19 ·
16K
  • · Replies 26 ·
