| Thread Closed |
Power generation and storage |
Share Thread | Thread Tools |
| Mar25-04, 08:00 AM | #1 |
Hi,
I am unsure which forum is most appropriate for this query but i'll start here. I am interested in building a device which works on the principle of using a stationary bike to drive an electrical generator to produce electricity, and, if practical, store it efficiently. Ultimately the energy produced by peddling the bike (by myself) I would like to use to power a set of 4x55watt flourescent bulbs in my hydroponics setup. I am a complete beginner and therefore do not expect a thorough technical plan on how to build such a setup more a point in the right direction for resources on which you think may be helpful. Also is this project a feasible one or would the power produced via peddling (a reasonable amount of exertion) be futile? Any suggestions would be greatly appreciated. |
| Mar25-04, 09:56 AM | #2 |
I'm no expert at all, I'm a beginer too, I was looking for the same thing you were except for a moving bike, My trouble is finding the whole storing concept. by the way if you plan to power up your what sounds like four 8'lights (I am a lighting sales asscociate) your right the do run at 55W but keep in mind they are made to hook up to a 120V AC system. Theres a transformer (balest) that converts it to the voltage and current required. I have no idea weather you can make something that powers straight to the bulbs.
As for your what you were looking for, here is a good link I found while doing my "research" http://users.erols.com/mshaver/bikegen.htm Good luck, if you find any good info out there let me know |
| Mar25-04, 02:14 PM | #3 |
Brilliant! Cheers for the link it had just the type of information I needed. I am also doing my own research and will post my findings from time to time if I find anything useful. Thanks once again.
| Mar25-04, 10:29 PM | #4 |
Mentor
DC generator->car battery->inverter->lights.
| May4-04, 07:23 PM | #5 |
Recognitions:
Building it off the grid eh?? Sounds like a plan. I hope you've got good insulation, heat sucks.
Anyhow, russ has it. Bike chain turns a gear on a generator (dc motor) to which the output charges a car battery. However, you will probably need some kind of voltage regulator to make sure you don't overcharge the battery. Anyhow, hook up an invertor (you can get them at walmart, advance auto, or pretty much anywhere the sales batterys) Probably need a beefy invertor, my 750w does pretty good, but only has 2 plugs. All in all, you'd probably have about $1000 tied up in the setup. Any ole cheap bike will do the trick. One thing I had considered was rigging the gearing system of a mountain bike on the generator shaft so I could shift gears. __ However, for what I think your trying to do, i do not think it will work. The lights have to be on for quite sometime, and will burn alot of power. If you've nothing better to do then peddle for 6 or 8 hours a day, shoot. The only way I could see it working is if you have some ole horse stamina, popeye legs and can run 2 generators at once charging several batteries at once. One car battery will likely last about 30-45 minutes running a single bulb you describe. You would probably need about 6-10 batterys, which could get costly. You may consider a large industrial battery, or large boat/heavy equipment batteries. |
| May6-04, 11:49 AM | #6 |
You will require approximately 8000 calories per day to do this work, if the caloric intakes of forest firefighters are good standards to go by of extreme work output. To calculate your food costs, adjust your present food costs to account for any discrepancy between your present caloric intake and the 8000 calorie figure. Performing this amount of work every day, you will also significantly shorten your potential lifespan by prematurely burning out your mitochondria. However, you may possibly be able to protect your mitochondria with one or more of the exogenously administerable mitochondrial antioxidants PBN, N-tert-butylhydroxylamine, N-acetyl-carnitine, liopic acid, idebenone, and coenzyme Q10. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Power generation and storage
| Wind power generation help please | Introductory Physics Homework | 3 | ||
| New Nuclear Power Generation in the US | Current Events | 3 | ||
| home power generation | Electrical Engineering | 9 | ||
| wind power generation | Electrical Engineering | 1 | ||
| Pumped Energy Storage and Available Power | Introductory Physics Homework | 3 | ||
