Velocity Split in T-Branch Pipe Flow?
  • Thread starter Thread starter TSN79
    Pipe
The discussion revolves around the flow characteristics in a T-branch pipe where a supply pipe splits into two branches. Participants explore the relationship between flow rate and velocity in the context of fluid dynamics, considering factors such as resistance and cross-sectional area.
  • Technical explanation, Conceptual clarification
  • One participant questions whether the flow through the two splits will have half the speed of the supply if the total flow is x.
  • Another participant suggests that if the resistance is the same in each branch, the flow through each branch would be (x/2) volume per unit time, implying a relationship to velocity.
  • A later reply indicates that if the cross-sectional areas of the branches are the same, the velocity will also be half.
Participants present multiple viewpoints regarding the relationship between flow rate and velocity, particularly in relation to resistance and area. The discussion does not reach a consensus.
Assumptions about resistance being equal in both branches and the areas being the same are not universally accepted or confirmed, leaving some uncertainty in the claims made.
TSN79
I have a supply pipe that splits into two using a T-branch. If the flow through the supply is x, will the flow through the two splits then have half the speed of the supply?
The flow into the T-branch is x volume per unit time. If the resistance is the same in each branch, then the flow through each branch is (x/2) volume per unit time. That's the same as x volume / 2 units of time.
- Warren
Great, thanks chroot!
...and if the areas are the same, the velocity will be half.
  • · Replies 31 ·
  • · Replies 38 ·
  • · Replies 21 ·
