What Angle Does the Muon Emerge at in Pion Decay?
The problem involves the decay of a pion into a muon and a neutrino, specifically examining the angle at which the muon emerges when the neutrino is emitted at 90 degrees to the pion's original direction. The context is rooted in relativistic particle physics, utilizing conservation laws for energy and momentum.
  • Participants discuss the setup of four-momentum conservation equations and the relationships between the momenta and energies of the particles involved. Some express frustration with the complexity of the expressions derived, while others suggest simpler approaches or highlight overlooked aspects, such as the initial velocity of the pion.
The discussion is ongoing, with participants exploring different formulations and expressing varying degrees of confidence in their approaches. Some guidance has been offered regarding the use of the initial velocity, and there is an acknowledgment of the need to simplify the problem.
Participants note the challenge of dealing with multiple unknowns in the equations, particularly the energy of the muon and the implications of the pion's initial velocity. There is a recognition of the complexity introduced by relativistic effects and the need for careful consideration of conservation laws.
Flux = Rad
I've done a countless number of these problems before, so I was quite annoyed when I was unable to do this one. It's from Griffiths' Intro to Elementary Particles.
A pion traveling at speed [tex]v[/tex] decays into a muon and a neutrino,
[tex]\pi^- \rightarrow \mu^- + \bar{\nu}_\mu[/tex]
If the neutrino emerges at 90 degrees to the original pion direction, at what angle does the muon come off?
Relativistic formulae for energy and momentum, energy and momentum conservation.
Note: in the following I've set [tex]c = 1[/tex]. If that bothers anyone too much, I could do it again keeping the c's in, but it's rather tedious.
I've set it up so that the pion was traveling in the [tex]\hat{x}[/tex] direction, and the neutrino goes off in the [tex]\hat{y}[/tex] direction.
The four vectors for the particles are:
[tex]P_\pi = \left( \begin{array}{cc} E_\pi / c \\ p_\pi \\ 0 \\ 0 \end{array} \right) \qquad P_\nu = \left( \begin{array}{cc} p_\nu \\ 0 \\ p_\nu \\ 0 \end{array} \right) \qquad P_\mu = \left( \begin{array}{cc} E_\mu / c \\ p_x \\ p_y \\ 0 \end{array} \right)[/tex]
4 momentum conservation states that
[tex]P_\pi = P_\nu + P_\mu[/tex]
Dotting both sides of this equation with itself, and noting that
a) the square of a 4 momentum is the rest mass of the particle
b) the neutrino is effectively massless
I get:
[tex]p_y = \frac{2 E_\mu p_\nu - m_\pi ^2 + m_\mu ^2}{2 p_\nu}[/tex]
If I rearrange my initial statement of energy/momentum conservation to
[tex]P_\nu = P_\pi - P_\mu[/tex]
the result of squaring this is
[tex]p_x = \frac{2 E_\pi E_\mu - m_\pi ^2 m_\mu ^2}{2 p_\pi}[/tex]
This allows me to obtain an expression for the required angle, namely
[tex]\tan \theta = \frac{p_y}{p_x} = \frac{p_\pi (2 E_\mu p_\nu - m_\pi ^2 + m_\mu ^2)}{p_\nu (2 E_\pi E_\mu - m_\pi ^2 - m_\mu ^2)}[/tex]
In order to get rid of the [tex]p_\nu[/tex] terms, I take my conservation master equation and rearrange it to the last possible arrangement, and square:
[tex]P_\mu = P_\pi - P_\nu \quad \Rightarrow \quad P_\nu = \frac{m_\pi ^2 - m_\mu ^2}{2 E_\pi}[/tex]
Substituting this into my rather messy equation for [tex]\tan \theta[/tex], I end up with:
[tex]\tan \theta = 2 \frac{p_\pi (E_\mu - E_\pi)}{2 E_\pi E_\mu - m_\pi ^2 m_\mu ^2}[/tex]
Clearly this isn't satisfactory since we don't know what [tex]E_\mu[/tex] is. I tried using the energy-mass-momentum relation to remedy this but I only managed to get
[tex]\tan \theta = 2 \frac{p_\pi(E_\mu - E_\pi)}{p_\mu ^2 - p_\pi ^2}[/tex]
which isn't of much help either, since we now have unknown [tex]p_\mu[/tex] terms floating about.
Hello,
I try this way:
Actually,conservation of momentum give [tex]p_\pi=p_x[/tex] and [tex]p_\nu=p_y[/tex]
Therefore,
[tex]\tan\theta=\frac{p_y}{p_x}=\frac{p_\nu}{p_\pi}[/tex]
where
[tex]p_\pi=\gamma m_\pi v[/tex]
and
[tex]p_\nu = \frac{m_\pi ^2 - m_\mu ^2}{2 E_\pi}[/tex] (you have got this relation)
Simplify further
[tex]\tan\theta=\frac{p_y}{p_x}=\frac{p_\nu}{p_\pi}=\frac{m_\pi ^2 - m_\mu ^2}{2 E_\pi}\frac{1}{\gamma m_\pi v}=\frac{m_\pi ^2 - m_\mu ^2}{2 \gamma m_\pi}\frac{1}{\gamma m_\pi v}=\frac{1}{2\gamma^2 v}\left(\frac{m_\pi ^2 - m_\mu ^2}{m^2_\pi}\right)[/tex]
Best regards
Without following all of the details (sorry, it's getting late), but you haven't used at all the fact that you were given the initial velocity of the pion is 'v'. This gives you a relation between E_pi and p_pi in terms of v. That's one less variable.
Thanks for the replies, I was making things way too complicated for myself. I'm not sure if the expression I got was correct but variation's method is far more elegant and uhm... logical. Hope that'll teach me to keep an eye on the bigger picture with simpler problems.
Thanks again.
