How Do You Calculate the Initial Velocity of a Bullet in an Elastic Collision?
The discussion focuses on calculating the initial velocity of a bullet in an inelastic collision with a block resting on a rough surface. The relevant equations include the work-energy theorem and the conservation of momentum. The derived expression for the initial velocity of the bullet is vi = +/- sqrt((vf^2 + (Mvf^2)/m + (2kx)/m)), where vf represents the final velocity of the bullet-block system. The key takeaway is to utilize conservation of momentum rather than work-energy principles due to the inelastic nature of the collision.
  • Understanding of inelastic collisions
  • Familiarity with conservation of momentum
  • Knowledge of the work-energy theorem
  • Basic grasp of friction and its coefficients
  • Study the principles of conservation of momentum in inelastic collisions
  • Explore the effects of friction on motion and energy loss
  • Learn how to apply the work-energy theorem in different collision scenarios
  • Investigate the relationship between mass, velocity, and kinetic energy
Students in physics, particularly those studying mechanics, as well as educators looking for examples of inelastic collisions and momentum conservation principles.
spectravoid
A bullet of mass m is shot into a block of mass M that rests on a rough surface with coefficient of kinetic friction k. The block slides for a distance of x meters before coming to a stop. Derive an expression for the initial velocity of the bullet.
0.5mvi^2 - k(-1)x = 0.5(M+m)vf^2 (work energy theorem just with the variables replaced with the ones in the question)
and also this but I'm not sure where to use it Ff = (M + m)gk
I need to remove vf
thank you for help
You don't want to use the work/energy stuff here. This is an INelastic collision. When the bullet collides with the block it is stopped by friction within the block and you have no data to calculate that directly. What you can count on is conservation of momentum. The initial momentum of the bullet is equal to the initial momentum of the bullet plus block combination. This will let you get an initial velocity for the block. Go from there.
  • · Replies 22 ·
