How Does Voltage Affect Electron Speed in a Magnetic Field?
The discussion revolves around the effects of voltage on the speed of an electron as it enters a magnetic field, specifically focusing on the relationship between electric potential, magnetic force, and the behavior of charged particles in magnetic fields.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the formula for magnetic force on a moving charge and its differences from that of a current-carrying wire. Questions arise about how to compute the speed of the electron from the given voltage and how this relates to the magnetic field strength.
Participants are actively questioning the relevant equations and concepts, particularly regarding the application of voltage in determining electron speed and the nature of the magnetic field. Some guidance has been provided on using potential difference to find the electron's speed, but there is no consensus on the approach yet.
There is some confusion regarding the definitions and applications of terms such as magnetic force, magnetic field, and the relationship between voltage and kinetic energy. Participants are also clarifying the units and meanings of terms like Tesla in the context of magnetic fields.
pattiecake
An electron is accelerated through 1800V from rest and then enters a uniform 2.90T magnetic field. What are the maxium and minium values of the magnetic force this charge can experience?
Ok someone help me out here...not sure of the equation. How do the formulas for a magnetic force differ between a line of current and a moving charge?
In this case I believe the formula is Fm=QVBsin(theta). The maxium & minium force will vary with the angle measure, i.e. sin(90)=max. But how does potential difference (1800V) come into play here? Where does the value of the magnetic field (B) come from?
Quick response here. 1800V is just to accelerate the electron to a certain speed before it enters the magnetic field. You need to compute that speed. A line of current? You mean a wire with current flowing through it? No this is not what the problem is about. The magnetic field about the wire is not uniform when you go peripendicular to the wire anyway. Not sure I know what F m v are. Force, mass, speed? Q = electron charge and theta = angle measured from electron's velocity to the direction of the field?
Yah basically I got all my equations confused...not sure which equation for a magnetic field applies to an electron here (and if there's a different equation that applies to, for example, a long straight wire with current running through...) Although I realize the problem only deals with the magnetic field surrounding this particle.
Fm=Fb=Force of magnetic field. B=magnetic field. v=velocity of the electron. Q = electron charge. And theta = angle measured from electron's velocity to the direction of the field.
Ok, now where does can I find the value for B?
2.90T I believe T stands for Tesla, the unit of magnetic flux density, webers per square meter. Also called magnetic field, B.
finding the electron speed
Use the potential difference to find the speed of the electron as it enters the magnetic field. The electron gains energy as it falls through the potential: KE = qV (where V is potential difference).
  • · Replies 25 ·
  • · Replies 31 ·
