Solving Difficult Problems: Tips & Strategies
  • Thread starter Thread starter apples and pears
    Tips
The discussion revolves around concepts related to light behavior, specifically focusing on Thomas Young's two-slit experiment, dispersion, and diffraction. Participants are exploring the relationship between wave theory and the phenomena of light splitting into colors with different wavelengths.
  • Participants are attempting to connect the concepts of dispersion and diffraction, questioning their differences. There is also a focus on understanding phase velocity and its implications in wave behavior.
The discussion is active, with participants seeking clarification on complex terms and concepts. Some guidance has been provided regarding the definitions of material and modal dispersion, but there remains a lack of consensus on the distinctions between certain terms and their implications.
Participants express confusion over terminology and concepts, indicating a need for further clarification. There is mention of an upcoming test, which adds a sense of urgency to the discussion.
apples and pears
And yeah, so how?
Thank you very much..
Look up Thomas Young's two-slit experiment.
cookiemonster
cookiemonster
I have done that, and I also know that his experiment does support the wave theory of light, but how does this relate to dispersion and the splitting of light into colours with different wavelengths?
Also, is dispersion and diffraction the same thing? I'm confused...
Sorry, you typed "dispersion" and I read "diffraction."
Dispersion supports the wave nature because dispersion depends on the frequency of the light wave. Actually, dispersion depends on the index of refraction which in turn depends on the phase velocity which in turn depends on the frequency, but you get the idea.
If light were not a wave and exhibited only particle properties, it would not disperse.
cookiemonster
No, they are different phenomena.
Wave theory explains refraction. Since light slows down when traveling through a medium (compared to vacuum), wave theory can explain why the light refracts (bends). Dispersion is due to different colors having slightly different speeds, and thus experiencing slightly different refractions.
What's phase velocity, cookiemonster?
I understand a little bit on what you said, but I kinda lost you when you said "phase velocity". Would you care to explain what that is? Thank you and sorry to be a pain.
Oh yeah, about material dispersion and modal dispersion:
Material dispersion - the spreading of a light pulse due to the dependence of the index of refraction on color (frequency).
Modal dispersion - the distortion of a light pulse due to the diverging path of the rays coming from the source.
Does anyone know what is the difference between spreading and distortion?
That's a tricky one.
The phase velocity is basically how quickly a given crest or node or static point on a wave is traveling in space. It's defined as
[tex]v_p = \frac{\omega}{k}[/tex]
where omega is the angular frequency and k is the wavenumber.
It sounds like material dispersion is like splitting the colors and modal dispersion is things be out of focus.
cookiemonster
cookiemonster
Um, sorry. I can't follow you. What's a given crest or node or static point on a wave is traveling in space?
Oh and thank you again. I really appreciate this. I got a major test on this on Monday. I'm so worried. I might not even pass it!
  • · Replies 32 ·
