Solving PDE with Green's Function: Finding Solution in Terms of G
The discussion focuses on solving the partial differential equation (PDE) \(\nabla^2 u = Q(x,y,z)\) in the half-space \(z > 0\) using Green's function \(G(x,y,z|x',y',z')\). The specific source term is given as \(Q(x,y,z) = x^2 e^{-z} \delta(x - 2) \delta(y + 1) \delta(z - 4)\). The solution is derived through the integral \(u(x,y,z) = \int_{-\infty}^{\infty} \int_{-\infty}^{\infty} \int_{0}^{\infty} G(x,y,z|x',y',z') Q(x',y',z') dz' dy' dx'\), which simplifies to evaluating \(G\) at the points defined by the delta functions. The approach is confirmed as correct, emphasizing the use of Green's function to solve Poisson's equation.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with Green's functions in mathematical physics
  • Knowledge of delta functions and their properties
  • Basic integration techniques in multiple dimensions
  • Study the derivation of Green's functions for the 3D Laplacian
  • Learn about the method of images for solving boundary value problems
  • Explore applications of Green's functions in electrostatics and fluid dynamics
  • Review integral transforms and their role in solving PDEs
Students and researchers in applied mathematics, physics, and engineering who are working on solving partial differential equations using Green's functions and require a deeper understanding of the underlying concepts and techniques.
Benny
Consider [tex]\nabla ^2 u = Q\left( {x,y,z} \right)[/tex] in the half space region z > 0 where u(x,y,o) = 0. The relevant Green's function is G(x,y,z|x',y',z').
Find the solution to the PDE in terms of G. If [tex]Q\left( {x,y,z} \right) = x^2 e^{ - z} \delta \left( {x - 2} \right)\delta \left( {y + 1} \right)\delta \left( {z - 4} \right)[/tex], find the solution in terms of G.
I'm using the result that the answer to a general problem of this sort will be the integral of the product of the Green's function and the 'source term'. So I find
[tex] u\left( {x,y,z} \right) = \int\limits_{ - \infty }^\infty {\int\limits_{ - \infty }^\infty {\int\limits_0^\infty {G\left( {x,y,z|x',y',z'} \right)Q\left( {x',y',z'} \right)dz'dy'dx'} } } [/tex]
Using the given expression for Q,
[tex] u\left( {x,y,z} \right) = \int\limits_{ - \infty }^\infty {\int\limits_{ - \infty }^\infty {\int\limits_0^\infty {G\left( {x,y,z|x',y',z'} \right)\left( {x'} \right)^2 e^{ - z'} \delta \left( {x' - 2} \right)\delta \left( {y' + 1} \right)\delta \left( {z' - 4} \right)dz'dy'dx'} } } [/tex]
I don't know if I've made a mistake somewhere so it'd be great if someone could check my answer. Also, can this be simplified? The integration region includes x' = 2, y' = -1 and z' = 4 so does the integral become G evaluated at x' = 2, y' = -2 and z' = 4 (multiplied by (x')^2exp(-z') evaluated at the same points)? Ie. G(x,y,z|2,-1,4).
Any help would be good thanks.
Thanks for the help. The first part of the question involved deriving the Green's function for the 3D laplacian but the question statement itself isn't clear cut on whether an answer in terms of G is acceptable or if the expression for the G must be used. So presumably, an integral expression, followed by a simplification of the integral using the properties of the delta function should be sufficient.
Do you by any chance have links to websites explaining the method of images? The book I have doesn't explain it too well for my purposes. I can do basic questions using that method but my solution method is more or less based on familiarity with examples rather than understanding so any links would be good, thanks.
  • · Replies 105 ·
13K
  • · Replies 40 ·
