| Thread Closed |
Whats the use of this? |
Share Thread | Thread Tools |
| May20-07, 05:22 AM | #1 |
Hello everybody,
I wanted to know the uses of such a function definition; f(x) = 3*f(x-1) - 3*f(x-2) + f(x-3) This works in linear and quadratic functions. I'll thankfull for your replies :) |
| May20-07, 05:55 AM | #2 |
Recognitions:
In what way does that 'work in linear and quadratic functions'?
| May20-07, 06:04 AM | #3 |
f(4) = 3*f(3) - 3*f(2) + f(1) which is true: 16 = 3*9 - 3*4 +1 this is what I meant... Do you know any intresting uses of such a thing? Thanks for contributing :) |
| May20-07, 08:40 AM | #4 |
Recognitions:
Let me explain how you can derive an equation like that one and why it works.
Say you started with a very simple linear recurrence relation, 1. f(x) = f(x-1) : This works for f(x) = 1. Now lets look for one that works for f(x) = x and also for f(x) = 1. Say f(x) = c f(x-1) + d f(x-2). Subst f(x)=1 and you find that "c+d=1". Next subst f(x)=x and you find that in addition to "c+d=1" we must also have "c + 2d = 0". Solving these give c=2 and d=-1. So our second recurance relation is, 2. f(x) = 2 f(x-1) - f(x-2) : This works with f(x) = 1 and with f(x) = x Similar working with three simultaneous equations you can find the coefficients of a third order linear equation that works for f(x)=1 and for f(x)=x and for f(x)=x^2. This one turns out to be the one that you started this thread with. That is, 3. f(x) = 3f(x-1) - 3f(x-2) + f(x-3) : This works with f(x)=1 and with f(x)=x and with f(x)=x^2 Note that these are all linear mappings of the form, f(x) = L{ f(x-1), f(x-2), ...} It is important to realize that these are all linear in "f", whether or not f is linear in x is irrelevant to this point. By linearity L{ a f_1 + b f_2 + ... } = a L{f_1} + b L{f_2} + ... So you can see for example that since the second relation above "works" for f_1(x)=1 and f_2(x)=x then it automatically must work for all linear functions f(x) = ax+b. For the same reason the third relation must hold for all quadratic funtions and so on. |
| May21-07, 09:05 AM | #5 |
Actually I have derived this one by myself but using a very different technique which is given as follows; lets say we have 3 consecutive terms; f(5), f(4) & f(3) . f(5) - f(4) = rate of increase between these terms. f(4) - f(3) = rate of increase between these terms, which is sth like first derivative. Now ; f(5) - f(4) - ( f(4) - f(3) ) = rate of increase between the rates of increase which is sth like 2nd derivative. 2nd derivative of quadratic and linear functions is always constant, using this fact and a little logic we'll have; f(5) - f(4) - ( f(4) - f(3) ) + ( f(5) - f(4) ) + f(5) = f(6) which means; f(6) = 3*f(5) - 3*f(4) + f(3) ---------- Thats what I did... So what are the uses of such function definitions? One use of this was solving projectile motion without being concerned about the equation of motion & having quick estimates for many functions without trying to evaluate the function's eq. especially when concerned with an irregular function. I'll be eagerly waiting for your reply :) Thanks once again. |
| May21-07, 11:03 PM | #6 |
So the essentials of this method uart is doing is to think up of a recurrence relation and find let certain functions you want the recurrence relation to work with, to find out the exact recurrence relation? Relating the functions
| Thread Closed |
| Thread Tools | |
Similar Threads for: Whats the use of this?
| Whats log? | General Math | 5 | ||
| whats your age? | General Discussion | 87 | ||
| Whats the name | General Math | 6 | ||
| 1 = 2?? whats going on here?? | General Math | 16 | ||
| Whats your Job? | General Discussion | 35 | ||
