What causes a shuttlecock to change direction mid-flight?
  • Thread starter Thread starter Milind_shyani
    Movement
The discussion revolves around the dynamics of a shuttlecock's flight, particularly focusing on the reasons behind its change in direction and orientation mid-flight. Participants explore the physics involved in its behavior during play, including the effects of air drag and the shuttlecock's design.
  • Some participants propose that the heavier bottom portion of the shuttlecock causes it to point downwards, while air drag affects its orientation during flight.
  • Others argue that the shuttlecock experiences a somersault effect not just at its peak height but almost immediately after being hit due to aerodynamic instability.
  • A participant mentions that the shuttlecock's rounded side leads in the direction of travel velocity, indicating a continuous adjustment in orientation during its flight.
  • One participant notes that the shuttlecock flips quickly when traveling nearly vertically, suggesting a relationship between its angle of ascent and orientation changes.
Participants express varying views on the timing and nature of the shuttlecock's somersault behavior, indicating that multiple competing explanations exist without a clear consensus on the exact mechanics involved.
Some assumptions about the effects of aerodynamic drag and the shuttlecock's design are present, but these are not fully resolved or quantified in the discussion.
This discussion may be of interest to those studying physics in sports, aerodynamics, or anyone curious about the mechanics of flying objects in a recreational context.
Milind_shyani
Quite a funny question
Now when we hit a shuttle cock by racket or any other means, the shuttle cock moves in the direction of the force but halfway the position of the shuttlecock changes ie in the beggning the cock faces us and then at halfway the cock starts facing the opposite player.
I hope you understand the question:smile:
What's your question, exactly?
I think I understand your question a bit.
The bottom portion of the shuttle cock being heavier than the feathery part has a tendency to point downwards always. Also air drag causes the feathery part to be pushed backwards, away from the opponent as the shuttle moves forward.
I believe this is the reason why they behave the way they should.
I don't think there's anything funny in the question, its a good application of physics to sports :smile:
Hi
Thankyou but then suppose that we have a single player and he just starts hitting the shuttle cock vertically in this case the shuttle cock travels vertical distance and then at the highest point it changes it behaves strangely ie in the beginning the cock faces us and and then it does something like a somersault and then at it starts coming downwards with the cock facing us.
Instead of just simply going up and then falling down it does something like a somersault at its peak position
It doesn't just do the sumersault at peak position (or halfway through it's trajectory), it does it almost immediately after being hit because flying backwards is very unstable due to aerodynamic drag forces.
Yes, I agree with russ. Air drag forces the shuttle cock rounded side to lead in the direction of travel velocity. The turn happens immediately after you hit it and again when the shuttle cock is moving downwards.
In fact, I just checked with a real one outside, to make sure. That's the first time physicsforums made me exercise!:biggrin:
Thank you all for the replies:smile:
The first 1/2 summersault is immediate, but the second one occurs just after the peak.
Well, the shuttlecock is really always pointed in the direction of motion, so it only really flips quickly if it is traveling nearly vertically.
  • · Replies 30 ·
28K
  • · Replies 24 ·
