What are the effects of quantum energy on macroscopic objects?
The discussion centers on the effects of quantum energy transitions on macroscopic objects, specifically comparing electron transitions in atomic theory to the movement of a lift. It concludes that while electrons emit photons when transitioning between energy levels, macroscopic bodies do not emit electromagnetic waves simply by moving. Instead, gravitational work is performed on massive bodies, and the quantum numbers involved in macroscopic systems are so large that energy transitions appear continuous rather than discrete.
  • Understanding of atomic theory and electron energy levels
  • Basic knowledge of quantum mechanics principles
  • Familiarity with concepts of gravitational work and potential energy
  • Awareness of the differences between microscopic and macroscopic systems
  • Research the principles of quantum mechanics and energy transitions
  • Explore gravitational work and its effects on macroscopic bodies
  • Study the differences between quantum and classical physics
  • Investigate the implications of quantum theory on everyday objects
Physicists, students of quantum mechanics, engineers interested in energy systems, and anyone exploring the relationship between quantum phenomena and macroscopic behavior.
thiotimoline
Hi to all, I have a quantum question to post here.
In the discussion on atomic theory, we know that electrons in different orbital levels have different quantum energy, say n=1 and n=2 have different energy levels. When one electron 'jumps' to another energy level, say from n=2 to n=1, the demotion will release a photon with energy equal to the energy level difference.
On a macroscopic level, if I take a lift from level 2 to level 1, do I release a photon of similar energy as well? Consider that a macroscopic body is also argued to be made up of billions of microscopic bodies. Similarly, if I take a lift from level 1 to level 2, do I absorb a photon which will increase my energy level relative to a fixed point, say the Earth's surface?
Pleae advise. Thanks.
From 2 to 1, the lift tries to recuperate your potential energy as much as possible. Much is lost in heat (friction losses) some is recuperated either in kinetic energy (in another lift or in a free wheel) or in electricity.
Since you are not a charged particles (you are not en electron) you cannot emit any electromagnetic wave just by moving. But since you are a massive body, gravity can produce work from your weight, and work is also needed to displace you.
The quantum numbers with a macroscopic system are so huge (~10^20) that the steps seem continuous, just as water seems continuous.
  • · Replies 38 ·
  • · Replies 23 ·
