Simple transform, wicked algebra.
  • Context: Graduate
  • Thread starter Thread starter brendan_foo
    Algebra Transform
The discussion revolves around a Fourier transform related to antennas, specifically the integral of a cosine function multiplied by an exponential term. Participants explore the algebra involved in simplifying the resulting expression into a trigonometric function.
  • Exploratory, Technical explanation, Mathematical reasoning
  • Brendan presents a Fourier transform integral and seeks a generalized result, noting the complexity of the algebra involved.
  • One participant suggests using the Euler's formula for cosine to simplify the integral, indicating that this could make evaluation straightforward.
  • Brendan clarifies that while he acknowledges the Fourier property, he is specifically looking for a way to combine the resulting sinc functions into a single trigonometric function.
  • Another participant offers a trigonometric identity that may assist in the simplification process.
  • Brendan expresses uncertainty about whether he will need to work through the algebra to achieve the desired result, referencing a potential application to field patterns in antenna theory.
Participants do not appear to reach a consensus on the best approach to simplify the expression, with multiple suggestions and methods being discussed without agreement on a definitive solution.
The discussion includes assumptions about the properties of Fourier transforms and trigonometric identities, but these are not fully resolved or detailed, leaving some steps and dependencies unclear.
brendan_foo
Hey folks,
I'm just searching for a generalized result here. Due to lack of note taking I am in a bind for this Fourier transform. The transform is...
[tex]\int_{-a/2}^{a/2} \cos (\frac{\pi x}{a}) e^{-j\beta s x} dx[/tex].
Of course, this is a general Fourier transform, although variables such as f and t are omitted as this is related to antennas.
Anyways, I figure that this is a product between a cosine function
[tex]cos(\pi x/a)[/tex]
and a unit rectangular pulse function between -a/2 and a/2. Of course, the Fourier modulation theorem states that we should have a transform of the form:
[tex]F(s) \sim sinc(0.5 a \beta s - \pi /a) + sinc(0.5 a \beta s + \pi /a)[/tex].
with scalar coefficients omitted for the sake of simplicity.
Anyways, I believe there to be an analytical expression for the sum of these Sinc functions, and it is allegedly a cosine function of certain parameters.
Anyways, the transform itself is complete from the general expression above, but the algebra is long winded to form it into another trig function.. Can anyone see a nice, glaring solution to this?
Cheers guys...
Brendan
cos(u)=(eiu+e-iu)/2
Substitute into your integral and evaluation is trivial.
Absolutely, and this general "Fourier property" indeed comes from the expansion into what I have listed above...the sum of sinc functions.
This is not the problem I am having. I am aiming to some how combine that sum of Sinc functions into a single trigonometric function. I am lead to believe that it is possible. When I leave the integral in its canonical exponential form, there is a lot of algebraic work to be done. I was just wondering if someone could see off the top of their head, or with a quick scribble on paper what this could be..
-Brendan
Perhaps this may be of use: [tex]\sin(x\pm y)=\sin x\cos y \pm \cos x\sin y[/tex]
I am almost sure that it is... Is this one of these occasions that I'm going to have to slug through it and feel good at the end if/when I get to the desired result?
This is just a possible question that may be posed, to determine a far E/H field using Huygen's principle and the argument passed to the F.T describes the field pattern of a horn-antenna aperture.
Back to the grind...
-Brendan
12K
  • · Replies 33 ·
