| Thread Closed |
Ice caps melting = water rising? |
Share Thread | Thread Tools |
| May25-07, 08:56 PM | #1 |
I've heard that if the ice caps melt the oceans will rise.
but i thought that water expands when freezing. is this a myth? |
| May25-07, 09:35 PM | #2 |
It does but the ice they are talking about is sitting on land rather than the sea.
| May25-07, 10:39 PM | #3 |
| May27-07, 09:22 AM | #4 |
Ice caps melting = water rising?It's true that most of the melting ice is on top of land, like the ice cap of Greenland. But then for the floating ice: Take a glass of water and put an ice cube into it. Wait until it melts. Which way did the surphase of the water in the glass move, up or down? Where will the expanded part of the wather when freasing to ice normally be located, for a floating ice cube ? |
| May27-07, 10:19 AM | #5 |
Mentor
| May27-07, 10:21 AM | #6 |
The density of floating ice vs. water has no effect on water level. See diagram.
| May27-07, 10:46 AM | #7 |
Shame, stupid me ..
| May27-07, 12:47 PM | #8 |
In the short term we shouldn't be too worried about ice bergs and ice shelves melting, because they are floating so when they melt they do not contribute to sea level rise. It is grounded ice that melts that will contribute to sea level rise, the largest ice caps on earth are grounded (e.g. Greenland, Anterctica).
Q/What is the single largest contributor to sea level rise? A/Thermal expansion. Because when you heat water up it becomes less dense (i.e. its volume increases), and because water is a fluid, it will spread its volume evenly over the entire ocean (ignoring self-gravitational effects). |
| May27-07, 02:33 PM | #9 |
| Jun21-07, 11:55 AM | #10 |
| Jun21-07, 12:41 PM | #11 |
Mentor
| Jun21-07, 12:56 PM | #12 |
The main concerns are the melting ice in Greenland and the Antarctic. Expansion of the water from heating is also a factor.
Evo, I was not aware of any predictions that water levels could fall in some areas. Where does this come from? |
| Jun21-07, 02:19 PM | #14 |
The most likely cause I can think of for the variability would be uplift and subsidence of the crust. E.g. SE England's coast will become submerged even if global sea levels do not change, the land is subsiding as mantle material diverges towards the north of Britain which is currently undergoing isostatic rebound in response to the melting of the ice cover at the end of the last glacial maximum.
| Jun21-07, 02:31 PM | #15 |
Meanwhile Hudson Bay and the Baltic sea are on it's way to become land.
| Jun21-07, 03:19 PM | #16 |
A rapid melt in arctic ice with an inhibited flow into the Atlantic could submerge islands in the arctic. The situation depends on whether the melting of ice is uniform or a sudden gush. I have to believe that either way, the melting of the artic ice cannot be felt uniformly throughout the world's oceans. If say for some reason, a large iceberg cuts off the Berring, and the arctic ice melts, there may be a chance the coastal regions of the Atlantic in England, North America and Europe could suddenly sea a sharp rise in ocean levels.
| Jun21-07, 07:30 PM | #17 |
It would have to be a very rapid melting for the effects to be felt locally at the scale that you are discussing, and besides even if there were a great flood, it would soon disperse.
| Thread Closed |
| Tags |
| evo |
| Thread Tools | |
Similar Threads for: Ice caps melting = water rising?
| Ice melting in water over time? | Introductory Physics Homework | 6 | ||
| Water Rising in a Diving Bell. | Introductory Physics Homework | 1 | ||
| melting ice and water displacement | Introductory Physics Homework | 3 | ||
| Ice melting in water | Introductory Physics Homework | 1 | ||
| Global warming = rising water level? | Earth | 25 | ||
