How to Calculate Time in Air for a Trebuchet Projectile?
The discussion focuses on calculating the time a projectile spends in the air when launched from a trebuchet with an initial velocity of 30 m/s at angles of 55, 65, and 75 degrees. The maximum heights achieved are 30.811 m, 37.71 m, and 42.842 m respectively. The user initially misapplied the vertical velocity in their calculations, using the total initial velocity instead of the vertical component derived from the angle. Correct calculations involve using the vertical component of the initial velocity, calculated as Uy = sin(angle) * initial velocity.
  • Understanding of projectile motion principles
  • Knowledge of trigonometric functions (sine and cosine)
  • Familiarity with kinematic equations
  • Basic physics concepts related to forces and motion
  • Learn how to derive vertical and horizontal components of velocity in projectile motion
  • Study the kinematic equations for projectile motion in detail
  • Explore the effects of air resistance on projectile trajectories
  • Investigate the use of simulation tools for visualizing projectile motion
Students studying physics, educators teaching projectile motion, and anyone interested in the mechanics of trebuchets and similar devices.
Marghk
I'm looking at trebuchets. Basically, a trebuchet shoots a projectile with an initial velocity of 30ms-1 at an angle of 55, 65 and 75 degrees. Friction/Wind resistance do not account.
I need to find the maximum height reached, the time the projectile spends in the air and the range. I am having troubles with the time spent in air, therefore affecting my last calculation.
I got a maximum height of 30.811m at 55 degrees.
37.71m at 65 degrees.
42.842m at 75 degrees.
As mentioned, I'm having trouble finding the total time spent in air. I know I have he following variables. I know that the time to reach max height x2 is the time of flight.
Y = vertical, X = Horizontal
Uy= 30ms-1
Vy = 0ms-1 (Obviously no movement at the exact highest point)
a= -9.8ms-2
Sy = 30.811m
I tried using the rule V = u+at
V=u+at
T=(v-u)/a
This gives me (0-30)/-9.8
Giving me 3.06 seconds and a total time of 6.122 seconds.
If I wanted to use that equation to find out the time taken if launched at 65 and 75 degrees, I would get the same answer due to the fact that vertical displacement isn't accounted.
I've been going over this again and again and I can't figure out anything.
Well actually there is movement at the highest point.
It has vertical and horizontal speed. The vertical speed is zero at the highest point, but the horizontal speed is constant.
You said that "Y = vertical, X = Horizontal", but you never seem to notice the horizontal.
When the angle is 55 for example, it has a vertical and a horizontal component.
Vy = sin 55 * v
Vx = cos 55 * v
So Uy is not 30ms-1.
I think you can solve it now.
EDIT: I just noticed that the values for maximum height are correct. So that's what you did (used vertical and horizontal components).
But then why are you using 30 m/s for (0-30)/-9.8 ? Shouldn't it still be sin 55 * 30?
You are only doing calculations vertically.
The acceleration only acts vertically, the final speed is zero only vertically, so then why use the resultant speed in the formula. You have to use the initial vertical speed as well.
Thanks, I just realized I wasn't calculating both horizontal and vertical attributes. Can't believe I missed that!
Thanks again :D
28K
  • · Replies 21 ·
