Center of mass of a rigid body-sphere
The discussion revolves around proving that the center of mass of a solid sphere is located at the origin using spherical coordinates. The original poster expresses confusion regarding the volume element in spherical coordinates and how to apply it in the context of the problem.
  • The original poster attempts to understand the volume element dV in spherical coordinates and questions why it cannot be represented as the square root of (dx+dy+dz). Participants discuss the transformation from Cartesian to spherical coordinates and the visualization of dV.
Participants are actively engaging with the original poster's confusion, providing insights into the nature of dV in spherical coordinates. Some suggest that the symmetry of the problem implies the center of mass must be at the center, while others emphasize the need for a formal proof through integration. The discussion is ongoing with multiple interpretations being explored.
The original poster is tasked with proving the center of mass explicitly, despite expressing difficulty in visualizing the volume element in spherical coordinates. There is mention of integrating over specific limits, but clarity on the integral setup is still being sought.
lewis198
I know this sounds silly, but I need to understand where I'm going wrong here.
Prove the center of mass of a spherical rigid-body (solid sphere) is found at the origin explicitly, using spherical coordinates (zenith, etc.).
Centroid center of mass equation.
I originally tried using my own spherical coordinates, then found the conventional ones. However I'm not sure what the value of dV would be. For example, why wouldn't every infinitesimal dimension of dV be the square root of (dx+dy+dz)?
thanks for reading this and any help you can offer.
Can you show us your work so far?
dV is the volume of infinitesimal of the sphere.
sqrt(dx+dy+dz)...I really don't know what's that supposed to mean.
Volume != sqrt(Length)
You probably mean: dV = dx*dy*dz. But those aren't spherical coordinates.
explanation
Sorry about that, all I can see dV as is dxdydz. However I think that would convert to r^2*sin(phi)*dr*d(phi)*d(theta) due to the Jacobian determinant, which I saw on wiki.
But why would dV be dxdydz? All I know is the transformation, but I just can't get my head round how you would determine what the spherical dV would be. In ares it would be polar and easy, even a cylinder most likely. But a sphere?
I assume that you're having difficulty picturing a volume element dV in spherical coordinates. dV in cartesian coordinates is trivial--just a cube of size dxdydz. But dV in spherical coordinates is a chunk of a sphere and thus a bit harder to visualize; This picture might help: http://www.spsu.edu/math/Dillon/VolumeElementSphericalCoordinates.htm"
By symmetry, if the COM is a point, it can only be at the center. You don't even need to know the eqn. for the COM to know that must be true.
I suspect that the OP is well aware of that, but is charged with carrying out the exercise nonetheless. (See the first post.)
OK, but why? The symmetry argument is a complete proof.
Thanks guys, I think that is enough material for me to work with. Thank you very much for your help.
Actually, I have a little question, if you would care to answer it. Is it possible to prove formally the limits on an integral? Generally even?
I don't understand the question. Perhaps you can rephrase it. The limits of the integrals needed in this exercise are well defined.
Did you do the exercise of setting up the integrals representing the x, y, and z coordinates of the center of mass in spherical coordinates? Once you do that, it's trivial to do the integration and show that the center of mass is at the center.
Guys to tell you the truth I just wanted to prove sophisticatedly Newton's shell theorem but i got over my head a little. I have tried repeatedly to get the value of rho, the origin to Point distance to zero through the supposedly simple proof, but to no avail. I integrate phi between zero and pi radians, theta between zero and 2 pi radians and rho between zero and R, the radius of the shell. I add phi, theta or rho in depending on which coordinate I want to find my COM in, and I get something ridiculous like 1/4*pi*R every time.
  • · Replies 25 ·
