Integration (terminal velocity)
The discussion revolves around the integration of four differential equations related to the motion of an object experiencing forces such as gravity and drag. The subject area includes dynamics and terminal velocity concepts.
  • Mixed
  • Participants explore the integration of equations with respect to different variables and question the clarity of the original problem statement. Some participants emphasize the need for proper use of the homework template and the importance of showing work done so far.
The discussion is ongoing, with participants providing guidance on the need for clearer problem definitions and questioning assumptions about the variables involved. There is a focus on ensuring that the original poster understands the integration process and the implications of the equations provided.
There are concerns about missing information, particularly regarding the variable "u" and the exact wording of the problem. Participants note that the integration process may be more complex than initially presented, especially given the non-linear nature of some equations.
kieran1black2
i have 4 equations that need to be integrated
1.) mg-kv-u=m*dv/dt
2.) mg-kv-u=m*v(dv/ds)
3.) mg-kv^2-u=m*dv/dt
4.) mg-kv^2-u=m*v(dv/ds)
**if it helps... the values are
m=3000
g=10
u= 172000
v changes so leave it as v
any help is good help
if those are finished can someone help me with the terminal velocity?
i think its when t --> infinity
You know what would be really helpful? Using the homework template provided on this forum i.e.
1. Stating the *exact* wording of the problem. (I highly doubt that "integrate these four equations" is exactly what you were asked to do. That statement doesn't even specify what the equations should be integrated with respect to! Note that these are first order differential equations for v(t), and two of them are non-linear. Solving them is likely to be more complicated than merely integrating.)
2. *Showing what work you have done so far*. We aren't going to do your homework for you. That doesn't benefit you in the slightest. We can guide you in the right direction, so that you learn things for yourself (which is the whole point).
That having been said, I can see that you have equations saying that the net downward force on a (presumably falling) object is equal to the downward force of gravity minus the upward drag force and also minus some other mysterious force, "u". What is u? And what exactly is the problem you have been given to solve?
Terminal velocity is not the velocity as t --> infinity. This makes little sense, as the object is unlikely to keep falling forever. Terminal velocity occurs when the drag force becomes large enough to counteract the gravitational force. As a result, the net force on the object is then zero, and it cannot speed up any further. It continues to fall at this contant velocity...the terminal velocity.
1.) mg-kv-u=m*dv/dt
left side with respect to dv
right side with respect to dt
right side with respect to ds
for question 4.) mg-kv^2-u=m*v(dv/ds)
i got (using the constant values
1/0.06*ln(|142000+0.03v^2|)=-1/3000*S+c
when S=0, v=1000
therefore c=200.921
-1/3000*S=1/0.06*ln(|142000+0.03v^2|)-200.921
when v=0, S=?
therefore S=9583.88 m
using this same method i need the others for 1.), 2.) and 3.)
I don't think you read all of my first post:
- you still haven't used the template
- you still haven't explained what u is
- you still haven't stated the exact wording of the problem*
- you still haven't really shown your work**
*Post #3 definitely isn't the original problem, because it makes no sense for 2 reasons:
a. One integrates with respect to v or t, NOT dv or dt. dv and dt are symbols used to denote integration with respect to v or t, respectively.
b. MORE IMPORTANTLY, you can't integrate the two sides of an equation with respect to different variables! Didn't this set off alarm bells in your head? It makes no sense. What you do to one side of the equation, you must do to the other (if you want the equality to hold true).
**When I say you didn't really show your work, what I mean is that you just wrote down the results of some integration operation, without putting in the steps that led to that result, making it impossible to determine what operation you carried out. (And substitution of the numbers really isn't helping in that regard. It makes it even harder to make heads or tails out of what you've done).
  • · Replies 19 ·
  • · Replies 27 ·
