Unit Commitment & Governor Gain of Power System: Help Needed
  • Thread starter Thread starter ineedmunchies
    Power Systems
The discussion revolves around the concepts of unit commitment and governor gain in power systems, focusing on how to determine which power plants to utilize based on various factors, including their operational characteristics and costs. Participants also explore the definitions and implications of governor gain and governor droop in the context of maintaining synchronization with the power grid.
  • One participant seeks clarification on the terms "governor gain" and "governor droop," suggesting they may be unique to their lecturer.
  • Another participant proposes that the governor controls turbine speed to maintain synchronization with the grid and questions what factors are involved in this process.
  • A different participant explains that governor gain affects the sensitivity of the governor to speed changes, noting that higher gain can improve synchronization but may lead to overly responsive behavior.
  • Governor droop is described as the difference between the speed setpoint and actual network frequency, allowing for load sharing among generators.
  • One participant suggests that the inquiry may relate to economic dispatch, questioning how much each unit needs to increase its output in response to demand changes.
  • A later reply indicates that the participant found relevant relations for calculating governor gain and droop, sharing a formula but expressing uncertainty about its broader applicability.
Participants express varying interpretations of governor gain and droop, with some providing technical explanations while others question their definitions. The discussion remains unresolved regarding the specific calculations and applications of these concepts in the context of unit commitment.
There are limitations in the discussion regarding the assumptions behind the calculations and the definitions of terms, which may depend on specific contexts or interpretations not fully explored in the thread.
ineedmunchies
I've come across a problem on unit commitment to a power system.
i.e. which power plants to use to power a system, which is determined by their loading range, incremental cost of power generation, and the cost of the station running at all.
However I'm being asked to also determine the governor gain of each operational unit (power station).
Anybody able to help me out?
What is governor gain and governor droop?
I can't find anything about them online, I have a feeling they're perhaps terms my lecturer has coined himself.
It sounds like the governor would help to control the speed of the turbines or something, to help keep the plant synchronized to the grid? What do your textbooks and other sources say about how to keep your plant synchronized to the grid? What factors are involved? How do you measure how much power you are putting into the grid (and therefore can charge for)?
Gain controls how sensitive the governor is to speed/frequency changes seen by that individual unit. A higher gain will result in faster synchronisation and better transient response, but may result in very 'twitchy' governor responses.
Droop is the amount by which the speed setpoint is above the actual network frequency. This mode of running allows a generator to 'load share' with the network to which it is attached, so that power output of that unit can be controlled.
No idea how you'd calculate these based on the information you've provided in your post though.
If this is an economic dispatch problem, then aren't they asking how much each unit on-line will need to increase (gain) for a given increase in demand? e.g. for a unit that is cold, you would have to look at start-up heating; for running units, some might be economical to ramp up more based on the system impedance than others.
Thanks for all of your answers, very helpful in understanding it. Its a simplified mix of what you've all been saying, its first a costing exercise, and then a problem about gain.
I found the relations i needed for my problem;
governor gain = -(delta P/ delta f)
Where delta f could be found using the governor droop value (delta f = governor droop(%) * f) where f is the original frequency.
I don't know if these will be any use to anybody.
  • · Replies 46 ·
  • · Replies 17 ·
  • · Replies 16 ·
