| Thread Closed |
Magnetic Field of a cylinder |
Share Thread | Thread Tools |
| May31-07, 12:38 PM | #1 |
An infinitely long cylinder, of radius R, carries a "frozen-in" magnetization. parallel to the axis, [itex] M = ks\hat{z} [/itex] where k is a constant and s is the distance from the axis; there is no free current anywhere. Find the magnetic field inside and outside the cylinder 2. Relevant equations [tex] J_{b} = \nabla \times M [/tex] [tex] K_{b} = M\times \hat{n} [/tex] [tex] \oint B \cdot dl = \mu_{0} I_{enc} [/tex] 3. The attempt at a solution Here [tex] J_{b} = -k\hat{\phi} [/tex] and [tex] K_{b} = kR \hat{\phi} [/tex] so the field inside s<R [tex] B \cdot 2\pi s = \mu_{0} \int J_{b} da = \mu_{0} \int -k s'ds' d\phi' [/tex] so i get [tex] B = -\mu_{0} ks \hat{z} [/tex] but the answer is supposed to be positive... why is that? Am i supposed to include the surface current density to find the field? But for a question in the past (for a cylinder with magnetization [itex] M = ks^2 \hat{\phi} [/itex].. however that time the enclosed current in the enitre (s>R) cylinder was zero - there was symmetry between the two surface currents. The amperian loop was a circlular loop within the cylinder... Is this question to be solved differently because there is no symmtery between the surface and volume current densities? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Magnetic Field of a cylinder
| Magnetic field of a cylinder with an offset hole | Introductory Physics Homework | 16 | ||
| Magnetic field of rotating cylinder | Advanced Physics Homework | 6 | ||
| Electric Field outside a cylinder | Introductory Physics Homework | 50 | ||
| Magnetic Flux through a Cylinder | Introductory Physics Homework | 0 | ||
| Magnetic force on a cylinder | Classical Physics | 1 | ||
