Power Supply Leakage Current When No Load Is Applied
In summary: You can measure the current draw with the DVM on the AC line, and convert it to milliamps with a cordless calculator.
cepheid
Staff Emeritus
38
If I want to find out the current drawn by a power supply when no load is placed on it. It isn't obvious what this is in the datasheet, but under Safety, Regulartory, and EMI regulations, it does mention a leakage current on the order of microamps. Would that be it, or does that refer to something else?
You mean, the current drawn from the mains by a bench-top power supply? It won't be microamps. A precision power supply has a lot of control circuitry, display circuitry, etc. -- not to mention losses. You could measure it fairly easily with a clamp-style ammeter, but I don't know how common it is for power supply manufacturers to put this kind of info in their manuals.
- Warren
Hmm ok. No I was not talking about a laboratory power supply, but one of those dual output (5 V, 12 V) linear open chassis power supplies that just basically has a transformer on one side and some sort of circuit board on the other side, that, through magic (regulators etc) produces the DC outputs. Anyway, don't worry about it.
I believe the leakage current you are referring to ("safety" related) is the leakage current to Earth Ground. This is a safety/health concern because of the shock hazard. Depending on the input EMI filter configuration, you can end up with more leakage current to Ground than is permitted, especially for medical devices.
The no-output-load input power consumption will sometimes be specified for a power supply. It certainly is for power supply components, like linear voltage regulators, for example. If you need to measure it, get an AC current clamp from the electronics store (about $50) that you plug into your DVM. Then separate the Hot/Neutral wires in the supply cord somehow (carefully), and clamp the measuring device over either wire.
1. What is power supply leakage current when no load is applied?
Power supply leakage current is the small amount of electric current that flows through a power supply when it is connected to a power source but not supplying any power to a load. It is a result of the internal capacitance and resistance of the power supply components.
2. Is power supply leakage current dangerous?
In most cases, power supply leakage current is not dangerous. The current is typically very low (usually in the microamp range) and poses no risk of electric shock. However, it is important to ensure that the leakage current does not exceed safety standards for certain sensitive applications.
3. How is power supply leakage current measured?
Power supply leakage current is measured by connecting a multimeter in series with the power supply and measuring the current flow. It can also be calculated by dividing the voltage across the leakage resistance by the resistance value.
4. What factors affect power supply leakage current?
Several factors can affect the amount of leakage current in a power supply, including the design and quality of the components, the insulation and spacing of the circuit, and the temperature and humidity of the environment.
5. How can power supply leakage current be reduced?
Power supply leakage current can be reduced by using high-quality components, proper insulation and spacing in the circuit design, and keeping the power supply at a stable temperature. It is also important to regularly check and maintain the power supply to ensure it is functioning properly.
  • Electrical Engineering
