Who's Right in Force Problem: Jeep vs Tractor
  • Thread starter Thread starter Zeth
    Force
In a tug-of-war scenario involving a 1400 kg jeep and a 2000 kg tractor, the tractor exerts a pulling force of 1.50 × 10^4 N while its wheels apply a horizontal force of 1.60 × 10^4 N against the ground. The correct approach to calculate the tractor's acceleration involves using only its mass in conjunction with the net force acting on it, which is derived from the difference between the force exerted by the wheels and the opposing force from the jeep. The misconception that the total mass of both vehicles should be used arises from a misunderstanding of Newton's Second Law, which applies to individual objects unless analyzing the entire system.
  • Understanding of Newton's Second Law of Motion
  • Basic knowledge of forces and mass
  • Familiarity with calculating net forces
  • Concept of acceleration in physics
  • Study detailed applications of Newton's Second Law in various scenarios
  • Explore the concept of net force and its calculation in multi-body systems
  • Learn about frictional forces and their role in motion
  • Investigate real-world applications of force analysis in engineering
Physics students, educators, and anyone interested in understanding dynamics and force interactions in mechanical systems.
Zeth
I'm not looking for an answer, I was just wondering who was right:
In a tug-of-war, a jeep of mass 1400 kg and a tractor of mass 2000 kg pull on a horizontal rope in opposite directions. At one instant, the tractor pulls on the rope with a force of 1.50 × 10^4 N, while its wheels push horizontally against the ground with a force of 1.60 × 10^4 N. Calculate the accelerations of the jeep and the tractor, and the horizontal force of the wheels of the jeep on the ground.
Now the way I see it the force is the difference of the force on the wheels of the tractor and the ground, which is 1000N. But the mark scheme says that the acceleration due to that is just the weight of the tractor/1000 but I figure it should be the weight of the tractor plus the weight of the jeep/1000 since the rope is taught. Am I right?
Bump, anyone?
No, you are not right. You found the net force on the tractor; thus you would apply Newton's 2nd law to the tractor to find its acceleration. You'd use the mass of the tractor alone.
If you had the net force on the entire system of jeep+tractor, then you'd be able to find the acceleration of the system using the total mass.
  • · Replies 23 ·
14K
