| Thread Closed |
how to lift water out of a pool... |
Share Thread | Thread Tools |
| Jun5-07, 08:38 PM | #1 |
given, diameter and height of pool, depth of water, density of water and gravitational acceleration. g = 9.8 height is 4m 2r = 20m depth of water = 3.5m density =1000kg/m^3 So, I'm supposed to find how much work is needed in joules to lift the water out of the pool. 2. Relevant equations could I use density times gravity times volume to get my force? is my distance for my water to travel 4.5m? 3. The attempt at a solution Anyways, I've tried to use my volume for the pool and the volume I have of water * density *gravity to come up with my force and then used 4.5m as my distance to come up with my work needed to lift water out of a pool. I ended up with 1.08E7 joules but that's incorrect so any help would be appreciated. BTW, this is a cal 2 problem/integration problem |
| Jun5-07, 08:41 PM | #2 |
if it is a cal2/integration problem why aren't you doing any integration? do you know the formula for work?
| Jun5-07, 08:48 PM | #3 |
Admin
Use the volume of the water and the density to get mass. It would appear that the pool is a right circular cyliner.
Rasining a mass m some distance h in a gravity field producing a local acceleration g increases the potential energy by mgh. |
| Jun5-07, 08:53 PM | #4 |
I've tried integrating it and I've tried astronuc's advice with no success, any ideas?
| Jun5-07, 09:03 PM | #5 |
I'm retarded, integration works. Alright, so with a mixture of the advice, correct answer is 2474002 joules. Thanks again fellas.
| Jun5-07, 09:05 PM | #6 |
weight density = 9800 N/m^3
work = integral {0 to 3.5} (9800)(pi*10^2)(4 - y)dy work = 2.4 * 10^7 Joules |
| Thread Closed |
| Thread Tools | |
Similar Threads for: how to lift water out of a pool...
| running by the pool... | Precalculus Mathematics Homework | 5 | ||
| how could spring water lift a person? | Introductory Physics Homework | 4 | ||
| waves in a pool of water having a rubber sheet ground | Classical Physics | 1 | ||
| PF Hockey Pool | General Discussion | 2 | ||
| pool leak? | General Math | 1 | ||
