Find & Simplify Difference Quotient of f(x)=sq root x
The discussion revolves around finding and simplifying the difference quotient for the function f(x) = √x. Participants are exploring the steps involved in manipulating the expression to reach a simplified form.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss inserting (x+h) under the radical and subtracting the original function. There is a focus on the manipulation of the expression and the confusion surrounding the correct form of the difference quotient.
Some participants have provided guidance on rationalizing the numerator and clarifying the correct form of the difference quotient. There is an ongoing exploration of why the simplified form differs from the original expression, particularly in the context of limits in calculus.
There is mention of a textbook answer that differs from the participants' calculations, which raises questions about understanding the simplification process. The discussion also hints at the relevance of limits as h approaches 0 in the context of calculus.
kuahji
The question is "find and simplify the difference quotient."
Given function
f(x)=sq root of x
So what I did is insert (x+h) under the radical & got
sq root of (x+h), then I subtracted the sq root of x (original function)
My answer was sq root [(x+h) - sq root (x)] / h
The answer in the back of the book is 1 / [sq root (x+h) + sq root (x)]
I'm not understanding where I'm going wrong, the other problems didn't give me a problem, just this one.
multiply numerator and denominator by [sqrt(x+h) + sqrt(x)] ...
[sqrt(x+h) - sqrt(x)]/h * [sqrt(x+h) + sqrt(x)]/[sqrt(x+h) + sqrt(x)] =
[(x+h) - x]/[h[sqrt(x+h) + sqrt(x)]] =
h/[h[sqrt(x+h) + sqrt(x)]] =
1/[sqrt(x+h) + sqrt(x)]
Ok, thanks!
So is there a reason why its listed in that form instead the other? I think that is what I'm not understanding.
you'll find out why when you have to take the limit of the difference quotient as h -> 0 ... it's a calculus concept.
Given function
f(x)=sq root of x
Not sure if this is a typo of a major misunderstanding. What you said you did is correct but you should have [sq root(x+h)- sq root(x)]/h. Do you see the difference? That is:
[tex]\frac{\sqrt{x+h}- \sqrt{x}}{h}[/tex]
where yours is
[tex]\frac{sqrt{x+h- sqrt{x}}}{h}[/tex]
As was said before, rationalize the numerator: multiply numerator and denominator by sq root(x+h)+ sqrt(x).
[tex]\frac{\sqrt{x+h}-sqrt{x}}{h}\frac{\sqrt{x+h}+\sqrt{x}}{\sqrt{x+y}+\sqrt{x}}[/tex]
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 21 ·
