What are the values of A, B, and C for rotating a line about the x-axis?
  • Thread starter Thread starter Amebos
    Coordinate
The values of A, B, and C for the surface generated by rotating the line y=7, x=7z about the x-axis are A = 1/49^2, B = 1/49, and C = 1/49. The initial calculations led to an incorrect assumption regarding the value of A, which was resolved by correctly substituting the values into the surface area equation Ax^2 + By^2 + Cz^2 = 1. The correct simplification process confirmed that A equals 1/49^2 after identifying the arithmetic error in the previous attempt.
  • Understanding of 3D geometry and surfaces of revolution
  • Familiarity with the equation of a surface in the form Ax^2 + By^2 + Cz^2 = 1
  • Basic algebraic manipulation and simplification techniques
  • Knowledge of parametric equations for lines in three-dimensional space
  • Study the derivation of surfaces of revolution in 3D geometry
  • Learn about the implications of rotating lines and curves about axes
  • Explore the application of parametric equations in surface equations
  • Practice solving similar problems involving surface area equations
Students studying calculus, geometry enthusiasts, and anyone involved in mathematical modeling of surfaces in three dimensions.
Amebos
Let L be the line y=7, x=7z. If we rotate L about the x-axis, we get a surface whose equation is Ax^2 + By^2 +Cz^2=1
What are the values of A, B, and C?
Listed above.
Since y=7, my first point that I plugged into the surface area equation is (0,7,0), and the solution I get is B= 1/49. I also know that rotation of the line will hit the point (0,0,7), yielding C =1/49. Now both of those solutions are correct. However, I can't seem to solve A.
I know that x=7z. z = (1/49) so x=(7/49), or x=(1/7)
I plug these values in the equation to get the following:
A(1/7)^2 +1/49(7)^2 +1/49(7)^2 = 1
Simplification yields:
(1/49)A +1 +1 =1
Further simplification yields:
(1/49)A = -1
Now shouldn't the answer just be:
A= -49?
I must have made an arithmetic error or simply chosen the wrong value for x. If someone could please guide me in the right direction it would be most appreciated. Thanks to you guys in advance.
Solved it.
I realized what my mistake was. I inserted the value for C into the place for the value of Z. Thus X=49 and the answer for A is
1/49^2
