Measuring Lightbulb Temperature: Spectroscopy and Thermocouples
  • Thread starter Thread starter raging_hippo
The optimal methods for measuring the temperature of a lightbulb involve two distinct approaches: spectroscopy for the filament and thermocouples for the bulb surface. For filament temperature measurement, utilize spectroscopy to analyze the emitted spectrum and fit it to the blackbody equation, while accounting for the bulb material. For surface temperature, employ the smallest thermocouple available, ensuring proper contact with thermally conductive grease, and experiment with varying grease spot sizes to assess their impact on accuracy.
  • Understanding of blackbody radiation and spectroscopy techniques
  • Familiarity with thermocouple operation and calibration
  • Knowledge of thermal conductivity and its effects on temperature measurement
  • Experience with data analysis and mathematical modeling
  • Research blackbody radiation and its application in spectroscopy
  • Learn about thermocouple types and their specific applications
  • Investigate methods for improving thermal contact in temperature measurements
  • Explore mathematical modeling techniques for correcting measurement errors
Researchers, engineers, and technicians involved in thermal analysis, materials science, or electrical engineering, particularly those focused on accurate temperature measurement techniques.
raging_hippo
What would be the best way to go about measuring the temperature of a Lightbulb? I've been set a task to measure the temperature of a lightbulb as i increase the electrical power supplied to it and i was just wondering what would be the most practical way to do it.
Any help would be greatly appreciated :biggrin:
I've already tried doing it that way but its not really accurate enough. Any other ideas?
Do you want the temperature of the filament, or the surface?
For the filament, do it spectroscopically. Take a spectrum and fit it to the blackbody eqation. If possible, make an estimate to correct for the material of the bulb.
For the bulb, use the smallest thermocouple you can find. Contact the thermocouple to the bulb with thermally conductive grease. Make several contacts of varying size to see if the size of the grease spot makes a difference. If it does, try to determine the effect and eliminate it mathematically.
Njorl
  • · Replies 16 ·
  • · Replies 30 ·
10K
