Electric Flux through an Infinite Plane due to a Point charge
The problem involves calculating the electric flux through an infinite plane due to a point charge of 43 microcoulombs located 48 meters away. The subject area pertains to electrostatics and electric fields.
  • The original poster attempts to apply known equations for electric flux and electric fields but expresses confusion regarding the infinite nature of the plane and the lack of surface charge density. Some participants suggest considering the fraction of the total flux that passes through the plane instead of calculating it directly.
The discussion has progressed with some participants providing guidance on alternative approaches to the problem. The original poster initially struggled but later indicated successful submission of their answer, suggesting that a productive direction was found.
The original poster mentions having completed other problems in the assignment, indicating a level of understanding but encountering specific challenges with this problem. There is also a reference to the online submission process, which may impose constraints on how answers are formatted or calculated.
sharpnova
A point charge of 43 microcoulombs is located a distance 48 meters from an infinite plane. Determine the electric flux through the plane due to the point charge.
flux = integral E d A = enclosed charge / epsilon_0
E = kQ / r^2
Well first off. This is the first problem of the assignment. I've finished EVERY other problem including the ones that require me to actually work out line integrals. No problem. But this one is stumping me.
I know how to calculate say.. the electric flux through some area of the plane.. using flux = EA.. and if I had the surface charge density I could easily just use a cylinder (gaussian surface) to find the answer. But with an infinite plane.. with no mention of any of its properties.. I seem to have reached the limit of my understanding of flux.
I tried the obvious 43 microcoulombs / episolon_0 and that submitted as incorrect.
So I'm stumped and have no clue how to proceed.
Would I want to calculate the E? A distance is given. so I can find out kQ/(43m)^2 but then I need an area to multiply that by.. and infinity doesn't really lend itself well to multiplication. (at least not in the case where you're trying to submit the answer online)
If you want, you can find the field at any point on the plane and integrate to find the flux. But there's a much simpler way. Imagine the field emanating in all directions from the point charge. How much of it passes through the infinite plane? What fraction of the total flux?
Bam
Submitted and correct. Thank you.
I had a feeling it would be something embarassing :p
I have a feeling that you're in my class.
anyway, thanks for the tip, doc al...
