How Do You Calculate a Plane's Average Acceleration from Velocity Components?
The discussion revolves around calculating a plane's average acceleration based on its velocity components at two different times. The subject area includes kinematics, specifically focusing on acceleration derived from changes in velocity over time.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the definition of average acceleration and the formula used to calculate it. Questions arise regarding the correctness of calculations and the interpretation of units. Some participants express confusion about the relationship between velocity and acceleration, while others attempt to clarify the calculations needed for different components of acceleration.
The discussion is ongoing, with participants providing guidance on how to approach the calculations. Some have attempted to calculate the average acceleration components and are seeking confirmation of their methods and results. There is a recognition of the need to convert units appropriately, and multiple interpretations of the problem are being explored.
Participants mention constraints such as the need to adhere to homework rules and the challenge of working with incorrect previous attempts. There is also a focus on unit conversion from km/h to m/s, which is a point of confusion for some.
Abarak
At an air show, a jet plane has velocity components v_x = 625 km/h and v_y = 415 km/h at time 3.85 s and v_x2 = 838 km/h and v_y2 = 365 km/h at time 6.52 }.
2. Questions
Question A.
For this time interval, find the x component of the plane's average acceleration.
{I have already used all of my tries on this one and have moved onto question B}
Question B.
For this time interval, find the y component of the plane's average acceleration.
I tried 81.9 but it says it's wrong. ((415/3.85)+(362/6.52))/2 = 81.9??
Question C.
For this time interval, find the magnitude of its average acceleration.
Question D.
For this time interval, find the direction of its average acceleration.
Please help, I have no idea how to go about solving the above questions. I'm not looking for the answer, just a little guidance.
Thanks,
Abarak
first define average acceleration.
then, state the formula for average acceleration explicitly, then plug in the values
can't understand what u are trying here ((415/3.85)+(362/6.52))/2 = 81.9 ?
why divide the speed by time? acceleration is something different.
actually first define acceleration here...
yes:biggrin:
When I enter "-18.73" it tells me it's the wrong answer. That was the last attempt at the question so I need to move on to part C.
In part C I have no idea where to begin as the answer to part B was wrong...
I'm lost...
Abarak
but u forgot the units, ur equation is correct but the value at the end would not be 18,73 because the units do not correspond. one is km/h and the other is seconds
Argh, I caught that on a few other problems. Dang it...
Thanks for the help, it's really appreciated.
Abarak
can u now do the other two parts? C and D?
Well, I am doing some research on them right now, trying to figure out how I can find the magnitude and direction from the two time's. I did find this list (http://www.grc.nasa.gov/WWW/K-12/airplane/translations.html) but it seems to just tell how to calculate average acceleration.
I know the velocity is a vector, indicating it has both a magnitude and a direction. Part C is asking to find the magnitude in km/h indicating a straight velocity. I think I know everything to finish part C and D but something is not clicking.
I'm a little lost. Could you possibly point me in the right direction?
After converting my units (_s>_hr) I came up with the following answers:
Part A: 287191.01 km/hr^2
part B: -67415.73 km/hr^2
after u calculate both of the accelerations (ax and ay) use pythagorean theorem to find the resultant acceleration and its direction
Hmmm... let me see if I got this right.
To find the magnitude:
x^2 = (287191.01 _km/_hr^2)^2 + (-67415.73 _km/_hr^2)^2
x = .036172991 _m/_s^2 or -.036172991 _m/_s^2
x = 486.802 _km/_hr^2 or -486.802 _km/_hr^2
Which one should I use? I'm thinking 486.802 _km/_hr^2 because it's (+).
Also, to find the direction I used:
sin(AavgX/AavgY) = sin(287191.01/-67415.73) = -.07 deg.
Are the above correct or am I way off?
x comp of average acc:
((838-625)/3,6)/(6,52-3,85)=22,16 m/s^2 in (+x)
y comp. of average acc.:
((365-415)/3,6)/(6,52-3,85)=5,202 m/s^2 in (-y)
magnitude of average acc.:
sqrt[(22,16^2)+(5,202^2)]=22,76 m/s^2
direction of average acc.:
arccos (22,16/22,76)=13,2 degrees
13,2 degrees S of E
Wow, I do suck at this stuff...
Thanks for all the help and time. Just one little question, when calculating the x and y average acceleration, you used 3.6. Where did this number come from?
Again, thank you for all of your help!
when converting km/h to m/s u divide by 3,6
1 km =1000 m
and 1 h= 3600 sec.
1000/3600=1/3,6
  • · Replies 20 ·
