Atomic physics: sodium D-line transition missing 2 pi
The discussion focuses on calculating the wavelength of the sodium transition from the 3p^{1},^{2}P state to the 3s^{1},^{2}S state. The initial approach using the energy equation E_{n,l} = -\frac{hcR}{(n - d(n,l))^{2}} did not yield accurate results. The correct formula for wavelength is confirmed as \lambda = \frac{hc}{\Delta E}, clarifying the confusion regarding the use of \hbar instead of h. The participant identified the missing factor of 2\pi in their calculations, which led to the misunderstanding.
  • Understanding of atomic transitions in quantum mechanics
  • Familiarity with the Rydberg formula for spectral lines
  • Knowledge of energy levels and quantum numbers
  • Basic grasp of Planck's constant (h) and reduced Planck's constant (\hbar)
  • Study the Rydberg formula in detail for various atomic transitions
  • Learn about the significance of quantum numbers in atomic physics
  • Explore the relationship between energy and wavelength in quantum mechanics
  • Investigate the role of Planck's constant in quantum equations
Students and educators in physics, particularly those focusing on quantum mechanics and atomic physics, will benefit from this discussion. It is also valuable for anyone involved in spectroscopy and the study of atomic transitions.
El Hombre Invisible
Find the wavelength of the sodium transition [tex]3p^{1},^{2}P -> 3s^{1},^{2}S[/tex]
[tex]E_{n,l} = -\frac{hcR}{(n - d(n,l))^{2}}[/tex]
d(3,s) = 1.374
d(3,p) = 0.884
[tex]\lambda = \frac{\hbar c}{\Delta E}[/tex]
Plugging the numbers in ain't even close. However, I've found another equation that works:
[tex]\frac{1}{\lambda} = -R[\frac{1}{(n_{i} - d_{i}(n,l))^{2}} - \frac{1}{(n_{f} - d_{f}(n,l))^{2}}][/tex]
but since E is proportional to [tex]\hbar[/tex] and the RHS on the top equation just to h... where did the [tex]2\pi[/tex] go..?
'Sokay. Just realized [tex]\lambda = \frac{hc}{\Delta E}[/tex] not [tex]\frac{\hbar c}{\Delta E}[/tex]. Knew it would be something stupid.
  • · Replies 0 ·
