What is the effect of a negative charge on the right hand rule?
The discussion revolves around the application of the right hand rule in the context of magnetic fields and charged particles, specifically focusing on the differences between positive and negative charges. Participants explore how the direction of magnetic force and field changes based on the charge type.
  • Participants discuss the implications of using the right hand rule for both positive and negative charges, questioning how the magnetic force direction changes with charge type. They explore examples involving circular motion in magnetic fields and the corresponding directions of forces and fields.
There is an ongoing exploration of the relationship between charge type and the application of the right hand rule. Some participants seem to reach a level of understanding regarding the opposite directions of forces for negative charges compared to positive ones, while others continue to seek clarification through examples.
Participants reference specific scenarios involving charged particles moving in magnetic fields, noting the importance of charge type in determining the direction of magnetic forces and fields. There is an acknowledgment of potential confusion regarding directionality in these contexts.
grscott_2000
Yesterday I asked a question regarding the right hand rule and Lorentz law. I now understand how the right hand rule is applied but the examples I have looked at all involve a positive charge.
My question is what effect does a negative charge have on the right hand rule?
If for example a positive charge is moving in a positive x direction when it enters a magnetic field and then starts to describe a circle in an anticlockwise direction (in the xy plane), by using the right hand rule I would say that the magnetic field would be in the positive z direction... Would you agree?
Now if a negative charge were to enter the same field and describes the same anticlockwise circle, how do I apply the right hand rule in this situation? Would I simple say, ok for a positive charge the direction of the magnetic field was in the z direction, so for a negative charge, the direction must be in the -z direction?
The direction of magnetic force on a negative charge will be opposite to that on a positive charge.
No. Using the right hand rule to compute [itex]\vec{F} = q\vec{v} \times \vec{B}[/itex] for a positive charge moving in the +x direction in a magnetic field in the +z direction I get an initial force in the +y direction--which means clockwise circle. (Viewed from above the x-y plane, where z > 0.)
I think you have your directions mixed up in this case, but your idea is correct: To get the same direction of force on a negative charge, the magnetic field must be opposite to what it was for the positive charge.
if u got the direction right, u can say that it is just the opposite for the negative charge.
therefore 2nd answer is -z and 3rd answer is +z
Ok, I think I understand... So if we know any two of either magnetic force, magnetic field or charge, by using the right hand rule we can find the third.
If the charge is positive then that's fine we go with the direction on the right hand, but with a negative charge it is simply the opposite direction to the right hand?
Let me give one more example to see if I've got it...
A negative charged particle enters a magnetic field in the positive x direction and the magnetic field is in the -z direction, the particle would experience a magnetic force in the -y direction and would describe a circle in a clockwise direction?
Exactly.
You got it.
Now apply Quantum wave observations to the particle in motion ^^
Tingle, brain! Tingle! >.<
  • · Replies 16 ·
  • · Replies 22 ·
