Feynmann diagrams, bhabha scattering
  • Context: Graduate
  • Thread starter Thread starter physics_fun
    Diagrams Scattering
The discussion revolves around the application of Feynman diagrams to Bhabha scattering, specifically focusing on the mathematical relationships between four-momenta in particle interactions. Participants explore various aspects of momentum conservation and the implications of on-shell conditions in the context of a homework problem.
  • Homework-related
  • One participant presents a four-momentum equation and questions the implications of defining certain momenta as zero, particularly in the context of Bhabha scattering.
  • Another participant suggests that if p3 equals p4, then the momenta must sum to zero, leading to confusion about the conditions under which this holds.
  • Several participants discuss the on-shell condition and its implications for the momenta involved, suggesting that p3 and p4 must be zero under certain conditions.
  • There is a debate about the interpretation of the inner product versus the cross product in the context of the momentum vectors, with differing opinions on how this affects the analysis.
  • One participant proposes that the relationship between the energies and momenta can only hold true under specific conditions, leading to the conclusion that either p3 or p4 must be zero.
  • Another participant emphasizes the need to simplify the problem using given relations before applying more complex mathematical operations.
  • Multiple participants express uncertainty about the implications of their calculations and the conditions under which certain equations hold true.
Participants express various interpretations of the mathematical relationships involved, with no clear consensus on the implications of certain definitions or the validity of specific approaches. The discussion remains unresolved regarding the exact conditions under which the momenta must be zero.
There are limitations in the assumptions made about the relationships between the momenta and energies, particularly regarding the definitions of the inner and cross products. The discussion also highlights the dependence on the specific diagrams contributing to Bhabha scattering.
This discussion may be of interest to students and researchers working on particle physics, particularly those studying scattering processes and the application of Feynman diagrams in theoretical frameworks.
physics_fun
There is nowone who can help me on the homework forum, so i'll try it here...
physics_fun said:
I'll try a little LATEX to make the problem more clear:
[tex] p_{1} + p_{2} = p_{3} + p_{4}[/tex]
These are four vectors of the in- and going momenta
You take the frame where the threemomentum [tex]p_{2}=0[/tex]
Questions:
1) Why does then defining threemomentum [tex]p_{4}=p_{3}[/tex] imply that [tex]p_{4}=p_{3}=0[/tex]? (threemomenta!)
And why does defining [tex]p_{3}*p_{4}=0[/tex] (three vectors) imply that [tex]p_{3}=0 or p_{4}=0[/tex]?
3. The Attempt at a Solution
I tried: 4-vectors: [tex] p_{1} + p_{2} = p_{3} + p_{4}[/tex]
square this: [tex](p_{1})^(2) + (p_{2})^(2) + 2p_{1}p_{2}= (p_{3})^(2) + (p_{4})^(2) + 2p_{3}p_{4}<br /> //<br /> (p_{1})^(2)=(p_{3})^(2)=m (electron mass)//<br /> (p_{2})^(2)=(p_{4})^(2)=M (positron mass)[/tex]
So: [tex]p_{1}p_{2}=p_{3}*p_{4}[/tex]
The lab frame condition gives:
[tex]p_{1}^{0}p_{2}^{0}=p_{3}^{0}p_{4}^{0}-p_{3}*p_{4}(three-vectors)[/tex]
But what are the next steps?
Thanks for your reply!
I still don't get it exactly
First Question:
If p3=p4, then p3-p4=0 and the moment of q=p1+p2=p3+p4, I don't get why it should be 0...
Second Question:
The '*' is the innerproduct (inproduct), so I don't know if then the rest of your reply holds?
First Question: (edited for the annihilation-creation diagram)
The answer follows from the on-shell condition.
E1+m = E3+E4, p1 = p3+p4
This means that E1 and p1 can only be on-shell if p3=p4=0
Second Question:
General advice: First try to simplify things with the given relations before
starting to take squares and things like that. Then use the on-shell
relations to prove the given restrictions.
I suppose the '*' is the cross product here. The cross product means that
p3 and p4 are in the same direction, thus (p4x,p4y,p4z) = a(p3x,p3y,p3z)
This gives us:
[tex]E_4+E_3\ =\ \sqrt{ a^2p_3^2 + m^2} + E_3[/tex]
Since p2= (m,0,0,0) we have q = (E1+m, p1x, p1y, p1z)
It follows that (p1x,p1y,p1z) = (1-a)(p3x,p3y,p3z)
This gives us:
[tex]E_1 = \sqrt{ (1-a)^2p_3^2 + m^2) }[/tex]
Thus:
[tex]E_3 = m + \sqrt{ (1-a)^2p_3^2 + m^2} - \sqrt{ a^2p_3^2 + m^2) }[/tex]
This means that either [itex]a[/itex] must be 0 and thus p4=0 or p3=0.
There is another solution and that is [itex]a=1[/itex]. In this trivial case p4=p3
and they can be non-zero...Regards, Hans
First Question:
To which of the two diagrams contributing to Bhabha scattering are you
referring to. The electron positron scattering or the annihilation/creation one?
Second Question:
It holds for the x product...:smile: (for the annihilation/creation diagram)Regards, Hans
Annihahilition: p1+p2(incoming momenta)=p3+p4(outgoing momenta)
Scattering: p1-p3=p4-p2 (toch?)
Doesn't it hold for the innerproduct?
OK, The answer then follows from the on-shell condition.
This means that E1 and p1 can only be on-shell if p3=p4=0Regards, Hans
Mmm...
I still don't get it completely:blushing:
:confused:
So p3 and p4 are under 90 degrees. It follows that:
[tex]p_{3\bot} = -p_{4\bot}[/tex]
[tex]p_{3\|} + p_{4\|} = q = p_1[/tex]
The latter is the same as
[tex]{p_1 \over |p_1|} \cdot p_3\ +\ {p_1 \over |p_1|} \cdot p_4\ =\ p_1[/tex]
The first left hand term is zero if the second one is at a maximum
and visa versa. For the energy we have:
[tex]E_1+m = E_3+E_4[/tex]
Now, p1 should be on shell so you have to prove that this is only
true in the two cases given above.
Regards, Hans
Ok, I think I'm getting it now:
E1, E2, E3 are the rest-energies, p1, p3, p4 the three vectors (p2 is defined 0)
Hans de Vries said:
You have:
E1 = E3 + E4 - m = 2E3 - m
and
p1 = p3 + p4 = 2p3
now
[tex]E_1^2 = p_1^2 + m^2[/tex]
thus
[tex](2E_3 - m)^2 = (\ 2p_3\ )^2 + m^2[/tex]
It follows that p3=p4=0
Regards, Hans
I'm understanding this one:cool:!
The factor 2 in 2p3 is true because p3 and p4 must be parallel to q and p1
otherwise it would be a variable.Regards, Hans
About the second: is it true that (threevectors:)
if p2=0, p1=p3+p4
so (p1)^2=(p3)^2+(p4)^2+2(p3)(p4)
now (p3)(p4)=0, so (p1)^2=(p3)^2+(p4)^2, and this can only be true if p4=0 or p3=0?
Hans de Vries said:
The complete proof is a bit more involved since the factor 2 in 2p3 is true only if
p3 and p4 are parallel to q but you can replace the 2 in 2p3 with a variable and follow
the same logic.
Regards, Hans
small angle approximation:wink:
no, the 2 is true anyway :smile:, since p3 and p4 must be parallel to q and p1.
(I modified my post)
Regards, Hans.
if p2=0, p1=p3+p4
You've got an expression for p1 now, as well as E1+m = E3+E4.
Next thing is to prove that
is true only in the two given cases.
Regards, Hans
It's completely clear to me now!
Thank you very much for your help!:smile::smile::smile:
