Is work done in lifting an object with a spring more than lifting it with a rod?
The discussion revolves around the comparison of work done when lifting a heavy object using a spring versus a rod. Participants explore the implications of using a spring, including the work required to stretch it and the perceived weight of the object during the lifting process. The scope includes theoretical considerations and conceptual clarifications rather than practical applications or homework problems.
  • One participant calculates the work done when lifting an object with a rod and questions whether the work done with a spring would be greater or less, suggesting that the work done with a spring includes additional work to stretch it.
  • Another participant agrees that the work done against gravity remains the same, but emphasizes that the work done on the spring is recoverable as potential energy.
  • A participant introduces the concept of simple harmonic motion when a spring is released, noting that the extra force of the spring contributes to the acceleration of the object.
  • There is a discussion about the perceived weight of the object when lifted with a spring, with one participant suggesting it feels heavier if lifted faster than with a rod.
  • Another participant mentions that the perceived weight also depends on the characteristics of the spring and the timing of the lift, indicating that a weak spring may behave differently than a stiff one.
Participants generally agree that the work done against gravity remains constant regardless of the lifting method. However, there are multiple competing views regarding the additional work involved with the spring and the perceived weight of the object, leading to an unresolved discussion.
The discussion includes assumptions about the characteristics of the spring and the conditions under which the object is lifted, such as speed and timing. There are also unresolved variables regarding the specific properties of the spring and the weight being lifted.
This discussion may be of interest to those studying mechanics, particularly in understanding the differences between static and dynamic forces, as well as the implications of using different lifting methods in theoretical contexts.
Mr Virtual
Hi everyone
Please note: It is not a homework-type question. I haven't got springs in my course.
Suppose we have a rod, a spring and a heavy object of weight 50 N. If we lift the object with the help of a rod upto 1m, work done by us is 50*1=50 J.
Now we remove the rod and lift the same object with a spring. Will the work done in lifting it to the same height be greater or less than the work done in lifting it with a rod?
Also, will we feel the object to be heavier, lighter or equal to its actual weight when we lift it with a spring?
For a spring,
F = kx
W = 1/2 * k * x^2
(I know all of you know these simple formulae. Just for those who might have forgotten it for a short while)
As far as I know, when a spring is used in lifting, it first stretches until its restoring force becomes equal to the weight of the object (50 N). The amount of stretching depends on k (Hooke's constant).
After that the spring exerts same force (50 N) on our hand, just like in the case of lifting with a rod. The difference is just that this time work done is greater because, besides lifting the object to 1m, we have also had to do work in stretching the spring. Lesser the value of k, more will be the work done in stretching.
According to me, apparent weight of the object will remain same (50 N), no matter whether we lift it with a spring or a rod.
Am I right?
I know this is a stupid question, but I just wanted to assure myself.
Thanks
Mr V
Yes, you are correct.
The work done AGAINST GRAVITY will be the same. You will need to do work on the spring to extend it to the point that it exerts a 50N force on the weight, after which point you will lift the weight normally. The work that you've done on the spring is recoverable later since it's stored as potential energy in the spring.
To lift the weight, F = kx = Mg
=> x = Mg / k
W(spring) = 1/2 * k * x^2 = 1/2 * k * (Mg/k)^2
= 1/2 * (Mg)^2 / k
A rod is of course the limit of a spring as k-> infinity, and we can see here how in this case the work that you have to do against the spring tends to zero in this limit.
If you attach an object to a compressed spring and release it, you end up with simple harmonic motion and the extra force of the spring is absorbed in the acceleration of the object.
Lifting a 50n object with 50n of force imples an arbitrarily small acceleration and long time to lift the object.
Only if the rod is of a different (heavier, lighter)/same (equal) weight than the spring.
Actually, if we're supposed to consider the case in my post, the object will feel heavier when lifted with a spring if it is lifted faster than with the rod.
Then it also depends on the spring and the timing. A very weak spring will extent until it is a straight 'rod' (depending on the weight of the 'weight'), a very stiff spring will act act like a rod (depending on the weight of the 'weight'); if the weight is lifted fast on a 'medium' spring and you measure the 'feel' of the 'weight' of the object at the point where it 'could' feel weightless or even a 'negative' weight. (There's too many unknown variables.)
  • · Replies 128 ·
12K
  • · Replies 34 ·
  • · Replies 29 ·
  • · Replies 22 ·
11K
  • · Replies 24 ·
  • · Replies 27 ·
