Help with Derivation of Centrifugal Force Equation
  • Thread starter Thread starter lets_resonate
    Rotation
The discussion focuses on the derivation of the centrifugal force equation, specifically F_{centrifugal} = - m \omega \times \left( \omega \times r \right). The user seeks clarification on the coordinate transformation used in rotating reference frames, particularly the equation \left( \frac {d} {dt} \right) _{i} = \left( \frac {d} {dt} \right) _{r} + \omega \times. They express confusion regarding the application of Newton's second law in this context and the differentiation of velocity in rotating frames. Ultimately, they successfully derive the acceleration equation a_i = a_r + 2 \omega \times v_r + \omega \times \left( \omega \times r \right) but seek further understanding of the initial transformation.
  • Understanding of Newton's second law
  • Familiarity with angular velocity and acceleration concepts
  • Knowledge of vector calculus, specifically cross products
  • Basic principles of rotating reference frames
  • Study the derivation of the Coriolis effect in rotating frames
  • Learn about the mathematical foundations of vector calculus
  • Explore the implications of non-inertial reference frames in physics
  • Investigate applications of centrifugal force in engineering contexts
Students of physics, particularly those preparing for AP Physics, as well as educators and anyone interested in the mathematical foundations of dynamics in rotating systems.
lets_resonate
Hello world,
I'm trying to understand the derivation of the centrifugal force equation, [tex]F_{centrifugal} = - m \omega \times \left( \omega \times r \right)[/tex]. I used these pages to help me in my pursuit:
  • http://observe.arc.nasa.gov/nasa/space/centrifugal/centrifugal6.html"
  • http://en.wikipedia.org/wiki/Rotating_reference_frame"
However, I lack the background to understand either of these articles. This last school year, I completed AP Calculus and first-year high school physics. I understood the material fairly well, but it does not appear to be enough to figure out the concepts discussed here. I will be taking AP Physics, multivariable calculus, and linear algebra next year.
So, off we go:
1.
From the NASA article
We wish to express Newton's second law in a reference frame that rotates uniformly and with angular velocity w (units of radians per second) relative to our inertial reference frame. This is accomplished by applying the coordinate transformation
[tex]\left( \frac {d} {dt} \right) _{i} = \left( \frac {d} {dt} \right) _{r} + \omega \times[/tex]
Uhh... what? The derivative of what with respect to time? Omega times what? It appears this is some sort of a fill-in-the-blanks equation - just down below, they fill the blanks in with r. But can anyone explain the meaning of this equation? Why does it supposedly make sense?
By the way, the "times" symbol, [tex]\times[/tex], represents the cross product.
2.
From the NASA article again
Upon applying the coordinate transformation a second time, to [tex]v_i[/tex], we obtain an expression for acceleration [tex]a_i[/tex] in the rotating reference frame:
[tex]a_i = a_r + 2 \omega \times v_r + w \times \left( \omega \times r \right)[/tex]
It appears to me that to obtain [tex]a_i[/tex], they simply took the derivative of [tex]v_i[/tex], the equation for which is:
[tex]v_i = v_r + \omega \times r[/tex].
However, when I do it, I get a different result:
[tex]a_i = \frac {d} {dt} \left( v_i \right) = \frac {d} {dt} \left( v_r + \omega \times r \right) =a_r + \omega \times v_r + \alpha \times r[/tex]
I simply differentiated the expression for [tex]v_i[/tex], using the product rule for the cross product. Alpha is angular acceleration, which is the derivative of angular speed, omega. What did I do wrong?
For now, I'll be happy to just understand these 2 problems. I won't even begin about the Wikipedia article (any math-related Wikipedia article has a crushing effect on my self-esteem). If anyone can offer some help, I'll appreciate it highly.
1. is an equation of "operators". The idea is that it is true with any arbitrary function (say "f", "h", "r" or "[itex]v_i[/itex]") placed on the right of all three terms. (At first such equations might make more sense if you always explicitly write in "f(x)" where appropriate, but the other notation is more efficient.)
2. [itex]a_i[/itex] is the rate of change (in the inertial frame) of the velocity (in the inertial frame). The problem is that [itex]a_r[/itex] is supposed to represent the rate of change in the rotating (not inertial) frame of the velocity in the rotating frame, so substitute your eq.(1) for the (inertial frame) differential operator you tried using in your last equation (and note that [itex]\alpha[/itex] = 0).
Thank you for the help. I managed to derive the equation properly:
[tex]\left( \frac{d}{dt} \right) _i = \left( \frac{d}{dt} \right) _r + \omega \times[/tex]
This "transformation" is first applied to r:
[tex]\left( \frac{dr}{dt} \right) _i = \left( \frac{dr}{dt} \right) _r + \omega \times r[/tex]
And then to [itex]v_i[/itex]:
[tex]\left( \frac{d}{dt} \left( v_i \right) \right) _i = \left( \frac{d}{dt} \left( v_i \right) \right) _r + \omega \times v_i[/tex]
Now substitute every [itex]v_i[/itex] on the right side of this equation with [itex]v_r + \omega \times r[/itex]:
[tex]\left( \frac{d}{dt} \left( v_i \right) \right) _i = \left( \frac{d}{dt} \left( v_r + \omega \times r \right) \right) _r + \omega \times \left( v_r + \omega \times r \right)[/tex]
After simplifying, I finally obtained the result I was looking for:
[tex]a_i = a_r + 2 \omega \times v_r + \omega \times \left( \omega \times r \right)[/tex]
Phew!
Well, everything makes sense, except for the very first step. I'm not sure how they obtained the original coordinate transformation in the first place:
I think I understand the concept of "equation of operators" now, but I don't understand why it is what it is. Why is it that a differential change (of something) in the inertial frame is equivalent to the same differential change (of the same something) in the rotating frame plus the angular velocity multiplied by that "something"?
Again, I would appreciate any help. Thank you in advance.
  • · Replies 17 ·
  • · Replies 17 ·
