Solving Physics Problems: Mass, Force, Moment of Inertia, Angular Speed
  • Thread starter Thread starter DeBbIeFrIcKeNrAy
This discussion addresses two physics problems involving mass, force, moment of inertia, and angular speed. For the first problem, a 12 kg mass attached to a cord experiences a force of 24 N, a moment of inertia of 0.12 kg·m², and an angular speed of 40 rad/s after 2 seconds. The second problem involves a 3 kg bucket falling under gravity, resulting in a linear acceleration of 9.8 m/s², a drop distance of 78.4 m, and an angular acceleration of the cylindrical pulley calculated at 16.3 rad/s².
  • Understanding of Newton's second law (F=ma)
  • Knowledge of rotational dynamics (moment of inertia)
  • Familiarity with angular kinematics equations
  • Basic concepts of gravitational acceleration
  • Study the application of Newton's laws in rotational motion
  • Learn about the relationship between linear and angular acceleration
  • Explore the concept of torque and its effect on rotational dynamics
  • Investigate the principles of energy conservation in mechanical systems
High school physics students, educators teaching mechanics, and anyone seeking to strengthen their understanding of dynamics and rotational motion concepts.
DeBbIeFrIcKeNrAy
I need help with two problems for my homework set in my high school physics class.
A 12 KG mass is attached to a cord that is wrapped around a wheel with a radius of 10.cm, the acceleration of the mass down the frictionless incline is measured to be 2.0 m/s2 Assuming the axle of the wheel is to be frictionless determine
a. the force in the rope
b. the moment of inertia of the wheel.
c. the angular speed of the wheel 2.0 s after it begins rotating, starting from rest.
A cylindrical 5.00 kg pulley with a radious of .6m is used to lower a 3.0 kg bucket into a well. The bucket starts from rest and falls for 4.0 s.
a. what is the linear accerleration of the falling bucket
b. how far does it drop?
c. what is the angular accerleration of the cylindrical pulley?
please i have no clue where to start on these...
yeah, what you said, haha
For the first problem, we can use the equation F=ma to determine the force in the rope. Since the mass is accelerating at 2.0 m/s^2, the force must be equal to 12 kg x 2.0 m/s^2 = 24 N.
To find the moment of inertia of the wheel, we can use the equation I=mr^2, where m is the mass and r is the radius. In this case, the moment of inertia would be 12 kg x (0.1 m)^2 = 0.12 kgm^2.
To find the angular speed of the wheel after 2.0 seconds, we can use the equation ω=ω0 + αt, where ω0 is the initial angular speed (which is 0 since the wheel starts from rest), α is the angular acceleration, and t is the time. In this case, we know that α = a/r = 2.0 m/s^2 / 0.1 m = 20 rad/s^2. So, ω = 0 + 20 rad/s^2 x 2.0 s = 40 rad/s.
For the second problem, we can use the equation a=g to find the linear acceleration of the falling bucket, since the only force acting on it is gravity. So, a = 9.8 m/s^2.
To find the distance the bucket drops, we can use the equation d=1/2at^2, where d is the distance, a is the acceleration, and t is the time. In this case, d = 1/2 x 9.8 m/s^2 x (4.0 s)^2 = 78.4 m.
To find the angular acceleration of the cylindrical pulley, we can use the equation α=a/r, where a is the linear acceleration and r is the radius of the pulley. So, α = 9.8 m/s^2 / 0.6 m = 16.3 rad/s^2.
I hope this helps you solve the problems and understand the concepts better. It's always important to start by identifying the given information and the equations that can be used to solve the problem. Then, make sure to use the correct units and plug in the values to get the final answer. Good luck with your homework!
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 19 ·
