A block sliding down an incline
The discussion focuses on the physics of a block sliding down an incline and subsequently on a flat surface. The block starts from a height of 4.7 meters on a 30-degree incline, resulting in a speed of 6.887937 m/s at the bottom. The coefficient of friction is 0.28, which affects the block's deceleration on the ground. Participants suggest using kinematic equations and work-energy principles to calculate the distance the block will slide before coming to rest.
  • Understanding of kinematic equations, specifically v = v0 + at
  • Knowledge of forces, including friction and gravitational components
  • Familiarity with work-energy principles in physics
  • Basic proficiency in solving equations involving acceleration and distance
  • Calculate the deceleration due to friction using f = μN
  • Learn how to apply the work-energy theorem to solve for distance
  • Explore kinematic equations, specifically v² = u² + 2as, for motion analysis
  • Investigate the effects of varying coefficients of friction on sliding distance
Physics students, educators, and anyone interested in understanding dynamics and motion on inclined planes and flat surfaces.
Momentum09
A block starts from rest at a height of 4.7m on a fixed inclined plane tilted at 30 degrees. The coefficient of friction is 0.28. If the block continues to slide on the ground with the same coefficient of friction, how far will the block slide on the ground until coming to rest?
2. V = V0+ at
3. I found out the speed of the block at the bottom of the ramp, which is equal to 6.887937 m/s. I led Vf = 0, V0 = 6.887937, and a =2.5236 [solved from gsin(delta) - ugcos(delta). Solve for t, and plug this value into the delta x = volt + 1/2 at^2 equation. I am not sure if I'm doing the right thing.
Thank you so much!
How did you get to that speed at the bottom of the ramp? Show your calculations please.
Thank you so much!
Either calculate the force due to friction and hence the deceleration and use [tex]\ \ v^2=u^2+2as[/tex] or use the work energ concept, [tex]\ \ W_{nc}=E_f-E_i[/tex], where W_nc is the work due to friction and [tex]\ \E_f-E_i[/tex] will be same as [tex]K_f-K_i[/tex]
  • · Replies 27 ·
11K
  • · Replies 45 ·
