Electric Fields in Parallel Plates
The discussion revolves around the behavior of electric fields in a parallel plate capacitor when the charge on each plate is increased. Participants are exploring the relationship between charge, voltage, and electric field strength.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to relate the increase in charge to changes in electric field strength, questioning whether the electric field increases by a factor of 3 or 9, or remains unaffected. There is also discussion about the relevant equations, including E = V/d and Q = CV, and how they apply to the problem.
Some participants are providing hints and guidance on the definitions and relationships between capacitance, charge, voltage, and electric field. There is an ongoing exploration of how these concepts interrelate, with no explicit consensus reached yet.
Participants express confusion regarding the equations related to charge on the plates and the implications of increasing charge on the electric field. The discussion is framed within the constraints of their current understanding and the equations they have been taught.
salman213
1. The magnitude of the electric field between two plates of a parallel plate capicitor is 4.7 x 10^4 N/C, if the charge on each plate increases by a a factor of 3, what happens to the electric field?
increase by a factor of 3 or 9?
decrease by a factor of 3 or 9?
not effected?
2. Electric field for plates = V/d
3. Thate the only equation i know and we did not learn any equation that reprensets charges on each plate so I am totally confused about how to relate the question...
maybe logically?
Umm since the charge on each plate increases by 3 the electric field will get stronger by the same factor of 3?
:confused:
I think you're on the right track, but you have to SHOW it. Hint: what's the definition of capacitance?
so i have to use formulas?
is therer a formula for te charge on a plate..? cause i only know
E = v/d and this ha snothing to do with increasing or decreasing distance or voltage, it has to do with charges on the plate,... :s
from what i found in my notes
i also have this equation
Ee = qV
but that q represents the charge on an electron between the two plates
so that's why i was thinking its more of a logical question that i don't get
rather than a mathematical proof .. but maybe it is i don't know...any advice?
ok i found Q= CV on the net
now i guess that means since E = V/d if E is increased then so does V and in turn so does Q ? cause its not being divided ... therefore it increases by a factor of 3 as well?
Yeah basically. The distance between plates doesn't change, therefore the capacitance doesn't, and tripling the charge means tripling the voltage means tripling the electric field.
  • · Replies 26 ·
  • · Replies 58 ·
  • · Replies 20 ·
