Recombination of plasma ions and electrons
The discussion focuses on the recombination of plasma ions and electrons, emphasizing that high temperatures and pressures prevent neutralization. It is established that recombination leads to energy loss in plasmas, particularly in fusion environments where temperatures reach keV levels. The ionization energies for hydrogen (13.6 eV) and helium (24.6 eV) are critical in understanding why recombination does not occur under these conditions. Additionally, bremsstrahlung and cyclotron radiation are identified as significant energy loss mechanisms in plasmas.
  • Understanding of plasma physics concepts
  • Knowledge of ionization energies for hydrogen and helium
  • Familiarity with energy loss mechanisms in plasmas
  • Basic principles of thermodynamics related to temperature and pressure
  • Research the effects of high-energy particle interactions on plasma states
  • Study the principles of bremsstrahlung radiation in plasma physics
  • Explore the role of cyclotron radiation in energy loss in plasmas
  • Investigate the conditions necessary for achieving fusion plasmas
Physicists, plasma researchers, and engineers working in fusion technology or energy loss analysis in plasmas will benefit from this discussion.
asdf1
If plasma is a collection of positive ions and electrons, why don't they recombine together and become neutral?
they will until the atom gets hit by a high energy particle and ionizes it again.
Recombination is a source of loss of energy from some plasmas.
Also, as malawi_glenn indicated, if the electron and ion temperatures are high, the electron will not recombine with the atom.
Consider that fusion plasmas have energies on the order of keV, and compare this with the ionization temperature of 13.6 eV for H, or 24.6 eV for 1st ionization energy of He.
http://facultyfp.salisbury.edu/dfrieck/htdocs/212/rev/table/ie.htm
The ions and electrons remain somewhat 'spatially' neutral, in that net positive or negative areas do not readily form.
Electrons also interaction the ions through brehmsstrahlung interaction, which is also a source of energy loss from plasmas, as well as cyclotron radiation.
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 0 ·
