How Do You Approach Reduction of Order for This Differential Equation?
  • Context: Undergrad
  • Thread starter Thread starter Matt Jacques
    Bit Reduction
The discussion revolves around the method of reduction of order for the differential equation vt'' - 3v' = 0. Participants explore various approaches to solving this equation, including integration techniques and the identification of solutions. The conversation includes technical reasoning and attempts to clarify the formulation of the equation.
  • Some participants suggest integrating the equation twice as a potential approach, while others question the formulation of the equation and the roles of the variables involved.
  • There is a proposal to factor the equation, although some participants express uncertainty about the correctness of this step.
  • One participant mentions a specific solution, v(t) = t^3, but later corrects themselves to acknowledge the existence of a constant solution.
  • A general solution is proposed as v(t) = C_1t^4 + C_2, but the derivation of this solution is not universally accepted.
  • Several participants discuss the need to treat the second derivatives carefully and suggest setting u = v' to transform the equation into a first-order form, leading to a different approach to solving it.
  • There are multiple suggestions for integrating and manipulating the equation, with some participants providing detailed steps while others express confusion or corrections to earlier claims.
The discussion contains multiple competing views on the correct approach to solving the differential equation, and participants do not reach a consensus on the best method or the validity of certain steps taken in the reasoning.
Participants express uncertainty regarding the treatment of derivatives and the formulation of the equation, indicating that assumptions about the variables and their relationships may not be fully resolved.
Matt Jacques
Although on the whole my Boyce & DiPrima book is fairly good in of itself and compared with others, but of-coarse some areas are lacking.
vt'' - 3v' = 0
I suppose I integrate twice, but then what?
vt''-3v'? You might want to check that, v and t are both functions of some parameter?
More specifically, v(t)*t'' - 3v(t) = 0
I'd go insane if I kept that (t) in there while differentiating and combining. :P
And that factorizes as:
v(t)*(t''-3)=0
not sure that's right either as now the second v is not primed.
v''(t)*t - 3v'(t) = 0
Sorry, this is it now.
Well, one solution is v(t)=t^3, don't you have to use this to get the other solution?
Edit, of course it isn't. There's the constant solution, duh, and that gives the answer in the next post.
The general solution
Hi;
The general solution is:
[tex]v(t)=C_1t^4+C_2[/tex]
Good luck,
Max.
add the 3v' to the other side getting:
vt''=3v'
divide v to the other side and then integrate with respect to t and v, based on the side of the equation, being sure to keep the integration constants in.
vt''=3v'
No, you cannot treat second derivatives like that. If you really had a single equation in two dependent variables, you will need another equation to get an explicite solutions just as you cannot solve one numeric equation in two variables.
The problem is, after editing, tv"j- 3v'= 0.
Matt Jacques, since you explicitely refer to "reduction of order", I think you mean this: set u= v' so that u'= v" and you have the first order equation tu'- 3u= 0. Now, you can do exactly what bowzerman suggested, since this is now a first order equation.
t du/dt= 3u so du/u= 3t dt. ln|u|= (3/2)t2+ C and then
[tex]u= C_1 e^{(3/2)t^2[itex].<br /> Since u= dv/dt, we have<br /> [tex]dv= C_1 e^{3/2}t^2 dt[/tex] <br /> and <b>only</b> have to integerate again. I'll leave that to you![/itex][/tex]
vt''=3v'
The problem is, after editing, tv"- 3v'= 0.
[tex]u= C_1 e^{(3/2)t^2[tex].<br /> Since u= dv/dt, we have<br /> [tex]dv= C_1 e^{3/2}t^2 dt[/tex] <br /> and <b>only</b> have to integerate again. I'll leave that to you![/tex][/tex]
yeah, sorry, I was just wrote that one too quick. Forgot to clarify.
oh, and shouldn't that be:
t du/dt = 3u
1/u du = 3/t ?
ln(u)=3ln(t) +C
u= c*t^3
, then sub, integrate, and then plug in?
  • · Replies 65 ·
10K
