| Thread Closed |
Question with Normal Force |
Share Thread | Thread Tools |
| Jun26-07, 02:12 AM | #1 |
I was doing a problem with normal force on an inclined plane and found the normal force by finding the y-component of the gravity vector. Then I also found that if I find the components of the normal force, I can also get another answer. -How are the 2 different equations available for the normal force the same 2. Relevant equations Fg = mg Fgy = -mgcos(theta) Fny = Fncos(theta) 3. The attempt at a solution Fgy = -mgcos(theta) Fn - mgcos(theta) = 0 'movement along plane; not vertically Fn = mgcos(theta) Fny = Fncos(theta) Fncos(theta) - mg = 0 'movement along plane; not vertically Fn = mg/cos(theta) I got 2 equations for Fn; Fn = mgcos(theta), Fn = mg/cos(theta)...I'm not understanding how the 2 are the same; can anyone help |
| Jun26-07, 04:49 AM | #2 |
Recognitions:
The object is accelerating, [tex]a[/tex], along the direction of the incline.
This means that in a direction perpendicular to the incline it is not accelerating as you correctly assumed in the derivation of your first formula. One can decompose the acceleration along the incline into x- and y- components though. This means that in the x and y direction one cannot assume that the acceleration of the object is zero. So your second formula is invalid. |
| Jun26-07, 05:14 AM | #3 |
I see; thanks. But, in that case, the second equation would work if lets say the object was moving perpendicular to the plane (such as a car on a banked road), right?
| Jun26-07, 07:27 AM | #4 |
Recognitions:
Yes, because the resultant acceleration is horizontal and there is then no vertical accelleration component.
| Jun26-07, 07:33 AM | #5 |
Alright; thanks
| Thread Closed |
| Thread Tools | |
Similar Threads for: Question with Normal Force
| calculating normal force and net force of 20 kg mass going down inclined plane at... | Introductory Physics Homework | 11 | ||
| Quick question on NORMAL FORCE | Introductory Physics Homework | 1 | ||
| Free body diagram involving normal force, gravitational force, and applied force. | Introductory Physics Homework | 4 | ||
| Question with normal force | Introductory Physics Homework | 15 | ||
| quick question about normal force... | Introductory Physics Homework | 10 | ||
