Does this expression make sense.
  • Context: Graduate
  • Thread starter Thread starter Klaus_Hoffmann
    Expression
The discussion centers on the convergence of the Cesàro sum expression as lambda approaches infinity. Specifically, the expression S(λ, δ) = ∑_{n ≤ λ} (1 - n/λ)^{δ} μ(n) is analyzed for its behavior under large lambda values. It is established that for finite lambda, S is finite, but the convergence as lambda increases is questioned. The conclusion suggests that S ∼ A + O(λ^{-b}) holds true, where b is a positive real number.
  • Understanding of Cesàro summation
  • Familiarity with asymptotic notation
  • Knowledge of mathematical series and convergence
  • Basic concepts of number theory, particularly related to functions like μ(n) and Λ(n)
  • Research the properties of Cesàro sums in number theory
  • Study asymptotic analysis techniques in mathematical proofs
  • Explore convergence criteria for infinite series
  • Investigate the behavior of specific arithmetic functions like μ(n) and Λ(n)
Mathematicians, researchers in number theory, and students studying advanced calculus or series convergence will benefit from this discussion.
Klaus_Hoffmann
i don't know where i saw the question is does this expression (Cesaro sum ??) make sense for big lambda and positive delta
[tex]\sum_{n \le \lambda } (1- \frac{n}{\lambda})^{\delta} \mu (n)=S( \lambda , \delta)[/tex]
for finite lambda the S is finite the question is what would happen as lambda goes to infinity ?, does the sum converge in the sense that for lambda big.
[tex]S \sim A+ O( \lambda ^{-b}[/tex] (b a positive real number)
and the same for
[tex]\sum_{n \le \lambda } (1- \frac{n}{\lambda})^{\delta} \Lambda (n)=S( \lambda , \delta)[/tex]
What have you tried to prove, or disprove, and how have you attempted to do it?
