Einstein-Hilbert action.
  • Context: Graduate
  • Thread starter Thread starter Klaus_Hoffmann
The discussion centers on the Einstein-Hilbert action, represented as I = ∫_{V} dV (-g)^{1/2}R or I = ∫_{V} dV ℒ(g_{ab}, Γ_{kl}^{i}). Participants explore the possibility of deriving Einstein's equations by independently varying the metric g_{ab} and the Christoffel symbols Γ_{kl}^{i}. This approach is validated through the Palatini formulation of General Relativity (GR), which, while yielding the same results as the metric approach for the standard Einstein-Hilbert action, diverges when generalized to include additional terms, such as in f(R) gravity models.
  • Understanding of the Einstein-Hilbert action in General Relativity
  • Familiarity with the concepts of metric tensors and Christoffel symbols
  • Knowledge of the Palatini formulation of General Relativity
  • Basic principles of variational calculus in physics
  • Research the Palatini formulation of General Relativity
  • Study the implications of varying both the metric and connection in gravitational theories
  • Explore f(R) gravity models and their differences from standard GR
  • Learn about the Levi-Civita connection and its role in General Relativity
This discussion is beneficial for theoretical physicists, graduate students in physics, and researchers focusing on gravitational theories and modifications of General Relativity.
Klaus_Hoffmann
if we have the Einstein Hilbert action
[tex]I= \int_{V} dV (-g)^{1/2}R[/tex] or [tex]I= \int_{V} dV \mathcal L (g_{ab}, \Gamma_{kl}^{i}[/tex]
then my question is if we can obtain Einstein equations by varying the metric and Christofell symbols independently i mean you get Einstein Field equations by
[tex]\frac{\delta I}{\delta g_{ab} =0[/tex] [tex]\frac{\delta I}{\delta \Gamma_{kl}^{i} =0[/tex]
i mean , you consider the metric g_{ab} and [tex]\Gamma_{kl}^{i}[/tex] as independent variables for your theory.
Yes, this is done in the so-called Palatini fromulation of GR. Google it to find more information. (if the action is simply the EH action, the Palatini formulation gives the same result as the usual metric approach. If the action is generalized to included other terms (liek a 1/R term as is done in some modedl of the so-called f(R) gravity, the Palatini formulation gives a different result than th emetric formulation.)
Patrick
Yes, if you vary the metric+connection EH action with respect to the connection, you find the algebraic equation: connection=levi-civita connection. Thus you can insert these equations of motion inside the action, recovering the metric-only EH action, and the two are classically equivalent.
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 37 ·
