Thread Closed
Metal bar on conducting rails
Share Thread
Jun30-07, 07:48 AM   #1
This is a Problem 7.7 fom Griffiths Introduction to Electrodynamics (3ed)
A metal bar of mass m slides frictionlessly on two parallel conducting rails a
distance l apart. A resistor R is connected across the rails and a uniform magnetic field B, pointing into page, fills the entire region.
If the bar moves to the right at speed v, what is the current in the resistor ?
2. Relevant equations
[tex]\Phi[/tex]=BACos[tex]\phi[/tex]
[tex]E[/tex]=[tex]\frac{d\Phi}{dt}[/tex]
3. The attempt at a solution
my reasonig is:
magnetic flux is:
[tex]\Phi[/tex]=BACos[tex]\phi[/tex]=BA=B(A0+A1).
A0 is initial surface, and A1 is surface which bar makes moving to the right with spead v.
so:
A1=x*l=v*t*l , but v is also function of t, so: A1=v(t)*t*l
I know that equation for A1 is wrong, becouse when I try to get electromotive froce
I get this:
E=d[tex]\Phi[/tex]/dt=B(0+v'(t)*t+v(t))
in solution manual it's:
E=Bl*dx/dt=Blv
Can someone explain why my reasoning is wrong, it seams logical to me.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jun30-07, 07:58 AM   #2
Mentor
Quote by natugnaro View Post
Setting x = v*t assumes that v is constant.
In any case, what matters is the rate at which flux changes, which depends on the speed at the moment in question:
d(A1) = l*v*dt
d(A1)/dt = l*v, even if v is changing.
Jun30-07, 08:21 AM   #3
Ok, than you.
That will help me to answer other question from that problem.
Thread Closed
Similar discussions for: Metal bar on conducting rails
Thread Forum Replies
Two rails and a rod (magnetic field) Advanced Physics Homework 2
Sliding Bar On Rails Advanced Physics Homework 5
Can a conducting metal plate connected to a +ve terminal of a battery gets charged? General Physics 2
Conducting sphere in a conducting spherical shell Introductory Physics Homework 2
conducting metal Introductory Physics Homework 6
