Why Does the Sun's Surface Gravity Seem So Low Compared to Expectations?
  • Context: Graduate
  • Thread starter Thread starter H8wm4m
    Sun Surface The sun
The discussion revolves around the apparent low surface gravity of the Sun compared to expectations based on current gravitational theories. Participants explore the implications of solar phenomena such as solar flares and solar wind, questioning how these observations align with theoretical predictions. The conversation touches on concepts from astrophysics and gravitational theory.
  • Some participants suggest that the nuclear reactions within the Sun push matter outward, which may not fully explain the observed behavior of solar flares and solar wind.
  • One participant questions the evidence for the low fall speed of solar flares and the speed of solar wind, asking for supporting statistics.
  • Another participant notes that the cause of solar wind's high speed and low deceleration remains unknown, and they observe that solar flares do not behave as expected.
  • Concerns are raised about the interpretation of visual evidence, with one participant emphasizing the limitations of still images in assessing solar phenomena.
  • Participants discuss the concept of the Sun's "surface," with some arguing that it is not a sharp boundary but rather a convention based on optical depth.
  • One participant proposes a project to estimate the Sun's surface gravity by analyzing video footage of solar flares and calculating their fall time.
  • Technical details are shared, including calculations of gravitational acceleration at the Sun's surface and the temperatures of different solar layers.
Participants express multiple competing views regarding the Sun's surface gravity and the behavior of solar phenomena. There is no consensus on the reasons behind the observed characteristics of solar flares and solar wind.
Limitations include the dependence on observational data and the unresolved nature of certain theoretical aspects related to solar dynamics and gravitational effects.
H8wm4m
Why does the sun appear to have such low surface gravity? Most would say the the nuclear reactions inside the sun continually pushes matter outward against the force of gravity, but this does not account for the slow fall of solar flares and speed of solar wind.
According to the current theory of gravity, the sun should have immense surface gravity. It simply does not appear to be so.
Astronomy news on Phys.org
wow, is that so?? i didnt knew it was!
but how do you know the fall of solar flares and solar wind on sun's surface are low?? i mean, are there any stats supporting this??
according to wikipedia, the cause of solar wind (at least the high speed and low deceleration) is still unknown.
as for solar flares, just looking at pictures and reading about them shows you they don't behave like they should
You can tell that by looking at pictures? Besides the obvious problem that still pictures aren't moving, do you have any concept of how big they actually are?
The sun's surface gravity is 28g. Whether that "appears" low, I don't know...
http://video.google.com/videoplay?docid=451080412925161409
here is a short video of the sun's surface, it shows plumes of hot gases, but no flares.
i don't know, the video does not seem to make any statement on the gravity of the sun.
i mean, you can't tell it by seeing the video
I know...
forgive me for making such an unverifiable and subjective claim in this topic
Here's a fun project for you: By studying video of solar flares (in conjunction with the solar radius, from wikipedia), figure out how high one goes. Then, by knowing how long it takes to fall, you should be able (2s=at^2) to estimate the sun's surface gravity yourself. o:) Then tell us how you went.
Stupid question:
Does the sun have a surface? I thought that it would be just a big ball of gas that gets thinner and thinner and finally just peters out. Wouldn't the surface we see be just an apparent surface due to photon scattering (where the atmosphere finally gets thin enough that most photons are no longer scattered)?
wildman said:
Stupid question:
That is right, the sun does not have a sharp surface. The surface of the sun is just a convention, that the surface is where the optical depth is 25 (or something, I have forgotten the exact numbers)
http://video.google.com/videoplay?docid=708234991989726743 - very large prominence. There is the matter of frame rate - time lapse - which would artificially speed up the event.
http://video.google.com/videoplay?docid=140644097329538951 - fast moving solar flare - I believe real time.
Please quantify 'immense'.
How about magnetohydrodynamics and the interaction of a hot plasma with intense magnetic fields.
try g=GM/R2 to see what the g should be in the chromosphere.
I come up with 274 m/s2 or 28g as Russ mentioned.
The escape velocity is ~620 km/s, and the solar flares are moving at 1000's of km/sec. Also be careful not to confuse particle (solar wind) velocity with the plasma wave velocities.
Temperature of the photosphere is about 5500 K, while that of the chromosphere is about 30,000 by some measurements and nearly 1 MK by others. The corona has a temperature of about 5 MK.
http://nssdc.gsfc.nasa.gov/planetary/factsheet/sunfact.html
See also - http://zebu.uoregon.edu/~js/ast122/lectures/lec12.html
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 21 ·
