Analyzing Rotational Motion with Newton's Second Law
The discussion revolves around a problem involving rotational motion and Newton's second law, specifically analyzing the forces and torques acting on a cylinder with a string wrapped around it. Participants are exploring the relationships between tension, angular acceleration, and linear acceleration in the context of the cylinder being held stationary while the hand exerts an upward force.
  • Mixed
  • Participants are attempting to derive the tension in the string and the angular acceleration of the cylinder using torque equations and force balance. Questions about the correctness of their reasoning and calculations are raised, particularly concerning the signs of forces and the application of Newton's laws.
There is an ongoing exploration of the problem, with participants questioning each other's reasoning and calculations. Some guidance has been offered regarding the application of torque and forces, but confusion remains about the implications of the upward acceleration of the hand and its effect on the system.
Participants are navigating assumptions about the forces acting on the cylinder, particularly the role of gravity and the tension in the string, while also considering the implications of the center of mass remaining stationary.
cristina
A string wrapped around a cylinder, and is held by a hand (to the up right of the cylinder so the cylinder is rotating clockwise) that is accelerated upward so that the centre of mass of the cylinder does not move. a) Find the tension in the string. b) Find the angular acceleration of the cylinder. c) Find the acceleration of the hand.
a)The only force that exerts the a torque on the cylinder is the tension:
Segma torque = I *alpha
T*R = I * alpha
The hand force is: Sigma Fy=ma,y
Mg – T = ma,t (I am not sure if its minus or plus here)
at=R(alpha)
(mg-T)/m=R(TR/I)
so T = mg/(1+(mR^2/I) this is the tension of the string
b) how to get the angular acceleration here?
c) mg-(mg)/(1+(mR^2/I)) = m a,t
so a,t =(1/(1+I/mR^2)g this is the acceleration of the hand.
Is my reasoning correct?
a) You know that the center of mass is not accelerated so
[tex]F_{net}=0[/tex]
Since there are only two forces, this should be fairily easy to apply
b) Once you have the torque, you can use:
[tex]\tau=I\alpha[/tex]
c) How about:
[tex]\theta = \frac{1}{2} \alpha t^2[/tex]
so
[tex]1/2 a t^2 = x = r \theta = \frac{1}{2} r \alphta t^2[/tex]
so
[tex]a = r \alpha[/tex]
Do you find it wrong in a) T = mg/(1+(mR^2/I) ?
I concidere I = 1/2MR^2 here
so torque = 1/2M(R^2) * alpha
but you said F,net = 0?
Was my reasoning correct with the calculation I gave?
I am confused.
There are two forces acting on the cylinder:
The tension of the string
Gravity.
Since the cylinder is stationary.
[tex]F_{net}=0=mg+T \rightarrow T=-mg[/tex]
The force of gravity is acting on the center of rotation so it exerts zero torque. That leaves the torque due to tension which is:
[tex]\tau= rT = -rmg[/tex]
Now we can use
[tex]\tau=I\alpha \rightarrow \frac{\tau}{I}=\alpha=\frac{-mgr}{\frac{1}{2}mr^2}=\frac{-2g}{r}[/tex]
But the hand is accelrating upward?!
I am really lost with this one :(
  • · Replies 21 ·
  • · Replies 97 ·
  • · Replies 22 ·
  • · Replies 29 ·
