Solving Improper Integrals: \int_{3}^{6}, \lim_{t\rightarrow\infty}
This discussion focuses on solving improper integrals, specifically \(\int_{3}^{6} (5-x)^{\frac{-1}{3}} \,dx\) and \(\lim_{t\rightarrow\infty} \int_{-t}^{t} \frac{x}{x^2 + 1} \,dx\). The first integral is solved using substitution with \(u = 5-x\), resulting in a value of \(\frac{9}{10}\). The second integral employs the limit comparison test, comparing it to \(\int_{-t}^{t} \frac{1}{x-1} \,dx\), leading to a limit of \(\frac{1}{2}\).
  • Understanding of integral calculus
  • Familiarity with substitution methods in integration
  • Knowledge of limit comparison tests for improper integrals
  • Ability to analyze functions graphically
  • Study substitution techniques in integral calculus
  • Learn about limit comparison tests for evaluating improper integrals
  • Explore graphical analysis of functions to estimate areas under curves
  • Review power rule applications in integration
Students, educators, and professionals in mathematics or engineering fields who are looking to deepen their understanding of improper integrals and integration techniques.
tandoorichicken
How do I do
[tex]\int_{3}^{6} (5-x)^{\frac{-1}{3}} \,dx[/tex]
I also need to know how to do
[tex]\lim_{t\rightarrow\infty} \int_{-t}^{t} \frac{x}{x^2 + 1} \,dx[/tex]
You could do both by substitution. Try the second one first. Define
[tex]u=x^2+1[/tex].
What is [tex]du[/tex]?
However, there is a hidden trick on the second one... draw the integrand as a function of x... can you tell its area from -t to t "by eye"?
To solve the first integral, we can use the substitution method. Let u = 5-x, then du = -dx. When x = 3, u = 2 and when x = 6, u = -1. Therefore, the integral becomes:
\int_{3}^{6} (5-x)^{\frac{-1}{3}} \,dx = -3 \int_{2}^{-1} u^{\frac{-1}{3}} \,du
Using the power rule for integration, we get:
-3 \int_{2}^{-1} u^{\frac{-1}{3}} \,du = -3 \left[\frac{3u^{\frac{2}{3}}}{2}\right]_{2}^{-1} = -\frac{9}{2} \left[\left(\frac{1}{2}\right)^{\frac{2}{3}} - \left(\frac{1}{5}\right)^{\frac{2}{3}}\right] = \frac{9}{10}
To solve the second integral, we can use the limit comparison test. First, let's rewrite the integral as:
\int_{-t}^{t} \frac{x}{x^2 + 1} \,dx = \int_{-t}^{t} \frac{x}{(x + 1)(x - 1)} \,dx
Now, we can use the limit comparison test by comparing it to the integral \int_{-t}^{t} \frac{1}{x-1} \,dx which is a known improper integral with a known solution. We get:
\lim_{t\rightarrow\infty} \frac{\int_{-t}^{t} \frac{x}{x^2 + 1} \,dx}{\int_{-t}^{t} \frac{1}{x-1} \,dx} = \lim_{t\rightarrow\infty} \frac{\frac{1}{2}\ln(t+1) - \frac{1}{2}\ln(t-1)}{\ln(t-1)} = \lim_{t\rightarrow\infty} \frac{\frac{1}{2}\ln\left(\frac{t+1}{t-1}\right)}{\ln(t-1)} = \frac{1}{2}
  • · Replies 16 ·
  • · Replies 16 ·
