So I came across these devices called lifters.
  • Context: Undergrad
  • Thread starter Thread starter Joza
The discussion revolves around the operation and effectiveness of devices known as lifters, which generate thrust through ionization of air. Participants explore the theoretical underpinnings, experimental observations, and practical limitations of lifters, particularly in different atmospheric conditions, including vacuum environments.
  • Experimental/applied
  • One participant describes lifters as devices that generate thrust when a high voltage is applied between an uninsulated wire and a cathode, suggesting that ionized air molecules accelerate towards the cathode, creating an upward force.
  • Another participant argues that a mesh screen is necessary instead of a solid sheet of foil to prevent cancellation of acceleration from impacts.
  • Some participants assert that lifters will not work in a good vacuum but may function in a poor vacuum, highlighting the challenges of achieving a good vacuum.
  • One participant shares an experiment where a lifter was sealed in a plastic bag, noting no weight reduction, which leads to the conclusion that thrust is produced by moving air molecules downward.
  • There is a claim that lifters cannot lift themselves off the ground with a conventional heavy high-voltage power supply and that using propellers may be more practical for propulsion.
  • Another participant expresses skepticism about claims that lifters can work in a complete vacuum, suggesting that such claims lack a credible mechanism and reiterating that thrust is derived from an imbalance of forces.
  • One participant emphasizes that lifters operate based on atmospheric ion/jet propulsion principles and are not examples of antigravity technology.
Participants express differing views on the effectiveness of lifters in vacuum conditions, with some asserting they cannot work in a vacuum while others suggest they might function in poor vacuum conditions. There is no consensus on the mechanisms or practical applications of lifters.
Participants note limitations regarding the effectiveness of lifters in vacuum environments and the challenges associated with the weight of power supplies needed for operation. There are unresolved questions about the mechanisms behind thrust generation and the practicality of lifters compared to other propulsion methods.
Joza
So I came across these devices called lifters. Basically, when a huge voltage is applied between an uninsulated wire and a a cathode (tin foil, in these lifters), thrust is generated and the device flies.
The idea is that the air becomes ionised at the anode and these ions accelerate towards the cathode. They push the anode away from them, which results in an upwards force.
The net upwards force is greater than the downward force because the ions smash into neutral air molecules while moving to the cathode, so their total momentum after colliding is less (the neutral air molecules have some of this momentum, and do not collide with cathode), and so less of a force is applied downwards. Thus, a net upwards force results, and lift occurs.This device, therefore, should not fly in a vacuum. However, I have heard conflicting reports.
I have heard that some experiments have shown a that they do work in vacuums, while others have not. I will post sources when I find them again.
Has anybody any ideas on this? (If this is in the wrong forum, move it lease, I do not mind!)
The cathode attracts the ionized air molecules.
You need a mesh (screen) not a sheet of foil, otherwise the impact will cancel any acceleration.
They will not work in a good vacuum, but may work in a poor vacuum.
It's hard to get a good vacuum.
Also, no one has yet built one that can carry the weight of the required power supply.
I've done a different experiment to it in that I sealed the lifter inside a plastic bag. It allows ionized air to circulate but to measure thrust, I have to put the lifter and the bag as one in a weighing scale. No weigh reduction is observed which means that lifter produce thrust by moving air molecules down.
I could say, that in a perfect vacuum, void of anything including subatomic particles, there's more likelihood, it will not produce thrust.
Its' also nearly impossible to have lifters lift itself off the ground with a conventional (heavy) HV power supply.
Since lifters could only operate with the presence of fluidic medium, it's a lot more convenient and practical to just use propellers for propulsion even if energy source is electricity. Also, the production of ozone makes lifters not a clean form of propulsion.
With a different design, I finally was able to produce reactionless thrust. But it strictly won't be discussed here.
So the bottom line is, the thrust is derived from an inbalance in upward and downward vector forces?
So I guess all the hearsay about them being able to work in a complete vacuum because of some other unknown mechanism is rubbish!
Thrust is derived by pushing air down by ionization, classic Newton's third law of motion. So yes, at least in a classic lifter design, anything you hear that it works in vacuum, it's an antigravity, etc. is rubbish.
Lifters are no antigravity, it's simply an atmospheric ion/jet propulsion engine, nothing more. It's good to note though that the volumetric efficiency in terms of thrust produced improves with speed like some sort of ramjet engine, but you'll need to have the electrode gap adjustable to take advantage of the effect.
  • · Replies 28 ·
15K
  • · Replies 21 ·
  • · Replies 46 ·
26K
