How to Calculate Golf Ball Range and Height Without Initial Velocity?
The discussion centers on calculating the range and maximum height of a golf ball hit at a 15-degree angle without a specified initial velocity. It is established that the problem can be solved by expressing the range and height in terms of the unknown initial velocity, denoted as v. The formulas for range and maximum height are derived using trigonometric functions and kinematic equations, allowing for a general solution based on the angle of projection.
  • Understanding of basic kinematics
  • Familiarity with trigonometric functions
  • Knowledge of projectile motion equations
  • Ability to manipulate algebraic expressions
  • Study the equations of projectile motion in detail
  • Learn how to derive range and height formulas for projectile motion
  • Explore the impact of different launch angles on projectile trajectories
  • Investigate the effects of air resistance on projectile motion
Students in physics, educators teaching projectile motion, and golf enthusiasts interested in the physics behind golf ball trajectories.
calalily_16
i'm really stuck on this problem, i need help desperately!
a golfer hits a golf ball across ground level at an angle of 15 degrees. what is the range and maximum height of the golfball?
i wasn't given any initial velocity so is this question doable?
It's doable if you express the answer in terms of the unknown initial velocity v.
  • · Replies 19 ·
  • · Replies 25 ·
17K
  • · Replies 21 ·
