Implicit Differentiation problem
The problem involves finding dy/dx using implicit differentiation for the equation y^2 + xsiny = 4.
  • Participants discuss the original poster's attempt involving dy/dt instead of dy/dx, with suggestions to clarify the differentiation process. There is also a focus on the importance of parentheses in the final expression for dy/dx.
Some participants have provided guidance on correcting the differentiation approach and emphasized the need for clarity in the expression. Multiple interpretations of the final expression for dy/dx are being explored, but no consensus has been reached.
There is a mention of potential confusion regarding the differentiation variable and the need for careful notation in the expressions derived.
suxatphysix
Find dy/dx by implicit differentiation when it is known that y^2 + xsiny = 4
2y dy/dt + xcosy dy/dt + siny = 0
2y dy/dt + xcosy dy/dt = -siny
dy/dt + dy/dt = -siny/2y/xcosy
I'm sure I'm doing it wrong so I stopped right there. What am I doing it wrong and how do I solve it?
Thanks
you're looking for dy/dx not dy/dt o.o, but assuming by dt you mean dx then in the 2nd line of your attempt you should pull out the dy/dt and the answer will be easy from there.
Is this the answer?
dy/dx = -siny/2y+xcosy
It would be if you would parenthesize the denominator.
dy/dx = -siny/(2y+xcosy) ? What's that's do
It distinguishes between -(siny/(2y))+(xcosy) and -siny/(2y+xcosy). Which are two quite different expressions. But look the same if you omit the parentheses.
1. Homework Statement
[tex]\frac{d}{dx}(y^2+x\sin(y)) = 0[/tex]
[tex]=2y\left(\frac{dy}{dx}\right)+\left[\frac{d}{dx}x\cdot\sin(y)+\frac{d}{dx}\sin(y)\cdot x\right]=0[/tex]
[tex]= 2y\left(\frac{dy}{dx}\right) + \left[\sin(y) + x\cdot\cos(y)\left(\frac{dy}{dx}\right)\right]= 2y\left(\frac{dy}{dx}\right) + \sin(y) + x\cos(y)\left(\frac{dy}{dx}\right) = 2y\left(\frac{dy}{dx}\right) + x\cos(y)\left(\frac{dy}{dx}\right) + \sin(y) = 0[/tex]
[tex]= \left(\frac{dy}{dx}\right)(2y+x\cos(y)) + \sin(y) = 0[/tex]
[tex]= \left(\frac{dy}{dx}\right)(2y+x\cos(y)) = -\sin(y)[/tex]
[tex]\left(\frac{dy}{dx}\right) = \frac{-\sin(y)}{(2y+x\cos(y))}[/tex]
Edit: I'm late by about 25 minutes. :biggrin:
cool thanks
  • · Replies 24 ·
