What is the initial velocity of the rocket?
  • Thread starter Thread starter suxatphysix
    Kinematic
The problem involves a rocket launch observed during a fireworks display, where participants analyze the time delay between hearing the launch and seeing the explosion. The explosion occurs at a distance of 50.0 meters at an angle of 73.0 degrees above the horizontal. The discussion focuses on determining the initial velocity of the rocket and its velocity just before the explosion, while considering the effects of gravity and the nature of the rocket's motion.
  • Participants raise questions about the rocket's acceleration and whether it acts differently in the x and y directions. There is discussion about the assumptions needed to solve the problem, particularly regarding constant velocity versus acceleration. Various equations are referenced, including those for projectile motion and uniform acceleration.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have suggested using equations relevant to uniform acceleration, while others are questioning the appropriateness of certain equations under the assumption of constant velocity. There is no explicit consensus on the approach to take.
Participants note that the problem may involve parabolic motion due to the rocket's acceleration under gravity, which complicates the use of certain equations. The time of 3.5 seconds and the observed angle and distance are key variables under discussion.
suxatphysix
A group of people are watching a fireworks display. 3.5 s after they hear a rocket launch, they see the explosion. the explosion is observed to be located 50.0 from the launch point at an angle of 73.0 degrees above the horizontal.
(a) Sketch the problem. Label all parts of the problem with the appropriate variables. This includes all variables you will use in your equations. Specify the value of all the variables you are given.
(b) What is the initial velocity of the rocket?
(c) What is the velocity of the rocket just before it explodes?
v = v0 + at
d=vt
First I have a couple of questions.
Is the rocket accelerating? If yes, is it in the x and y directions?
Is there an assumption I should be making to solve this problem?
cos73 = x/50m
x= cos73(50m)
x=14.62
sin 73 = y/50m
y=sin73(50m)
y=47.82
v = v0 + at
0 = v0 + (-9.80)(3.5s)
vy0 = 34.3 m/s
d=vt
v=d/t
v=4.18 m/s
Then I would use the pythagorean theorem to solve for the final velocity but this is all done assuming that the velocity was constant and that the rocket was not accelerating.
bump bump ////
suxatphysix said:
A group of people are watching a fireworks display. 3.5 s after they hear a rocket launch, they see the explosion. the explosion is observed to be located 50.0 from the launch point at an angle of 73.0 degrees above the horizontal. (a) Sketch the problem. Label all parts of the problem with the appropriate variables. This includes all variables you will use in your equations. Specify the value of all the variables you are given.
v = v0 + at
d=vt
cos73 = x/50m
x= cos73(50m)
x=14.62
sin 73 = y/50m
y=sin73(50m)
y=47.82
v = v0 + at
vy0 = 34.3 m/s
d=vt
v=d/t
v=4.18 m/s
the rocket is accelerating under the influence of gravity, so d=vt is not an equation you want to use. use the equations which are relevant for the case of uniform acceleration in the negative y-direction (at 9.8m/s^2) and no acceleration in the x-direction.
If we assume that the fuel is spent to launch the rocket then we are dealing with parabolic motion.
Note that the initial speed, [tex]V[/tex], can be calculated from the launching angle, [tex]\theta _o[/tex], and the horizontal speed, [tex]V_x[/tex] (which can be calculated from the given data - I would think that the given distance is actually the horizontal distance covered up to the point of explosion)
[tex]V = \frac{V_x}{\cos(\theta _o)}[/tex]
to determine the initial angle use the known distances covered in the given time
[tex]x = Vt\cos(\theta _o)[/tex] ... (1)
and
[tex]y = Vt\sin(\theta _o) - \frac{1}{2}gt^2[/tex]
transferring the last term (which can be calculated) to the left gives
[tex]y + \frac{1}{2}gt^2 = Vt\sin(\theta _o)[/tex] ... (2)
dividing (2) by (1) now gives the launching angle [tex]\theta _o[/tex].
  • · Replies 53 ·
