Solve 1st Order Diff Eq Using Integrating Factor: 2y/x + dy/dx = 1-2/x
The discussion focuses on solving the first-order differential equation dy/dx + (2/x)y = 1 - 2/x using the integrating factor method. The integrating factor is calculated as F = x^2, which transforms the equation into a form suitable for integration. The solution derived is y = (x/3) - 1 + (8/3x^2), with the constant C determined to be 8/3 based on the initial condition y(1) = 2. The key insight is recognizing that the left-hand side can be expressed as the total derivative of yx^2, clarifying the manipulation of terms during the solution process.
  • Understanding of first-order differential equations
  • Familiarity with integrating factors in differential equations
  • Knowledge of basic calculus, specifically integration techniques
  • Ability to apply the product rule in differentiation
  • Study the method of integrating factors in more complex differential equations
  • Learn about the application of initial conditions in solving differential equations
  • Explore the product rule in differentiation and its applications in calculus
  • Investigate other methods for solving first-order differential equations, such as separation of variables
Students studying differential equations, educators teaching calculus, and anyone looking to deepen their understanding of integrating factors in mathematical problem-solving.
Bucky
Use the integrating factor to solve the first order differential equation
subject to the initial condition y(1) = 2
I have the full answer (it's an example), but my lecturer is notorious for omitting steps, to my constant irritation. It might be fine for pure mathmaticians, but for some of us comp sci fakers, it makes everything much more difficult :wink:
[itex] P = \frac{2}{x}[/itex]
[itex] Q = 1-\frac{2}{x}? or just \frac{2}{x} ?[/itex]
Integrating factor is therefore
[itex]F = e^{2 \int \frac{1}{x}}<br /> ...<br /> F = x^2[/itex]
Upon multiplying by [itex]F = x^2[/itex], we find
[itex]x^2 \frac{dy}{dx} + 2xy= x^2 - 2x[/itex]
Where does the 2xy go?
[itex] ((x^2) y)' = x^2 + 2x[/itex]
so that
[itex] x^2 y = \int (x^2 - 2x) dx[/itex]
[itex] x^2y = \frac{x^3}{3} - x^2 + C[/itex]
when x = 1, y = 2
[itex] x^2 y = \frac{x^3}{3} - x^2 + C<br /> 2 = \frac{1}{3} -1 + C<br /> C = \frac{8}{3}[/itex]
therefore, sollution is
[itex] y = \frac{x}{3} - x + \frac {8}{3x^2}[/itex]
where did the x^2 come from at the end?
The point of the integrating factor is that you make the LHS of the equation look like the total derivative with respect to x of something. Consider this function:
[tex] f=yx^2[/tex]
y is a function of x, and x^2 is a function of x. what is the derivative of f? Use the product rule:
[tex] \frac{df}{dx}=\frac{dy}{dx}x^2+y\frac{d(x^2)}{dx}[/tex]
but of course I know the derivative of x^2 with respect to x, it's just 2x. I.e.
[tex] \frac{df}{dx}=\frac{dy}{dx}x^2+y2x[/tex]
In other words, I can rewrite
[tex] \frac{dy}{dx}x^2+2xy[/tex]
as
[tex] \frac{d(yx^2)}{dx}[/tex]
...that's where the 2x went.
...so, now I have
[tex] \frac{d(yx^2)}{dx}=x^2-2x[/tex]
then the integral of the LHS is trivial
[tex] yx^2=\int (x^2-2x)[/tex]
...and, well, the integral of the RHS is easy too
[tex] yx^2=\frac{x^3}{3}-x^2+C[/tex]
so then, dividing both sides by x^2 I find
[tex] y=\frac{x}{3}-1+\frac{C}{x^2}[/tex]
with C=8/3 this is
[tex] y=\frac{x}{3}-1+\frac{8}{3x^2}[/tex]
which would agree with your answer if you had divided by x^2 correctly. cheers.
  • · Replies 105 ·
13K
