Solving Trig Derivatives: Answers & Solutions
  • Thread starter Thread starter cd246
    Trig
The discussion revolves around the differentiation of trigonometric functions and the application of various rules such as the product rule and the chain rule. Participants are analyzing specific problems involving derivatives of expressions like sin²(t), (e²ˣ)(sin x - cos x), and sec²(x) - tan²(x) + cos(x).
  • Participants explore the use of the product rule and chain rule for differentiating trigonometric functions. There are attempts to apply trigonometric identities to simplify expressions, with some questioning the correctness of their approaches and the application of rules.
There is an active exchange of ideas with participants providing feedback on each other's attempts. Some guidance has been offered regarding the use of trigonometric identities and the differentiation of exponential functions. Multiple interpretations of the problems are being explored, particularly in the context of applying the quotient rule.
Participants express uncertainty about specific steps in their differentiation processes and the application of trigonometric identities. There are indications of confusion regarding the behavior of constants in differentiation and the correct application of rules to various terms.
cd246
1. Sin^2(t) The answer states sin2t
2. (e^2x)(sin x-cos x) The answer states (e^2x)(3 sin x- cos x)
3. sec^2(x)-tan^2(x)+cos(x) The answer states -sin x
1.product rule
2.product rule
3. sum and diff. rule?
1. (sin t)(sin t)'+(sin t)(sin t)'=(sin t)(cos t)+(sin t)(cos t)=2cos (t) sin (t)
2. (e^2x)(cos x+sin x)+ (e^2x)(sin x-cos x)=(e^2x)(sin 2x)
3. (sec^2(x)*tan^2(x))-sec^4(x)-sin x. I just don't know how to get rid of the first and second functions.
1.product rule
2.product rule
This is correct; you need to use a trig identity to get it in the form of the solution. Note that, alternatively, you could have used the chain rule for this question.
This isn't quite correct; what is the derivative of e^(2x)?
I'm not sure what you've done here. You want to differentiate the original term by term, so you need to find the derivatives of sec^2x and tan^2x. Can you write these as quotients and use the quotient rule?
For 1. I tried the chain rule(sin x inside, square outside), and it got me 2cos(t) which is worse than my first answer.
For 2. I assumed e never changes. And I never came across a problem where e changes and I am not too sure on how to do that. Is it 2 e^1?
For 3. If I am understanding this correctly, Instead of the original, say it as: sec^2(x)+cos(x)/tan^2(x) then apply the quotient rule?
If I am not correct, please guide me to the answer(s).
You made a mistake using the chain rule. Recall that [tex]\frac{d}{dx}((\sin x)^2)=2\sin x \cdot\frac{d}{dx}(\sin x)=2\sin x\cos x[/tex]. Now, can you spot the trig identity that will reduce the answer to the required form?
[tex]\frac{d}{dx}(e^{ax})=ae^{ax}[/tex] for some constant a.
No, I meant write the expression as [tex]\frac{1}{\cos^2x}-\frac{\sin^2x}{\cos^2x}+\cos x[/tex] and differentiate each term, using the quotient rule to differentiate the first two terms.
For 1, I am really not seeing how it becomes sin2t from 2sinx cosx.
For 2, I got it right, it was the derivative of e^2x that messed me up. thanks cristo.
For 3, I know ultimately the third term will be left and the other two will cancel each other out. This is what i got(by following the advice):
secx^2-tan^2+cosx
l
(1/cosx^2)-(sinx^2/cosx^2)+cosx.
f'(x)=(cosx^2-sinx^2/(cosx^2)^2)-(cosx^4+sinx^4)/(cosx^2)^2)-sinx. I know the exponents does not cancel in this step.
For 1 and 3, I know there is a step that I do not have any knowledge of(or i did a step wrong), thanks in advance.
Ok, it's just a trig identity you should remember. The identity is [itex]\sin(2x)=2\sin x\cos x[/itex]. It is derived from the multiple angle formula [itex]\sin(a+b)=\sin a\cos b+\cos a\sin b[/itex] by setting a=b
You're welcome
secx^2-tan^2+cosx
l
Ok, let's look at each term individually, since you have used the quotient rule incorrectly on (at least) the first term.
We want [tex]\frac{d}{dx}\left(\frac{1}{\cos^2x}\right)[/tex]. Using the quotient rule, this is equal to [tex]\frac{\cos^2x\cdot\frac{d}{dx}(1)-1\cdot\frac{d}{dx}(\cos^2x)}{(\cos^2x)^2}=<br /> \frac{2\cos x\sin x}{\cos^4x}=\frac{2\sin x}{\cos^3x}[/tex]
Now, try to do the second term (sin^2x/cos^2x) again. I'm not sure how you got what you did first time.
3. sinx^2/cosx^2
(cosx^2)(sinx^2)'-(cosx^2)'(sinx^2)
(cosx^2)^2
(cosx^2)(2 cos x sin x)+(2 cos x sin x)(sinx^2)
(cosx^2)^2
(2 cosx^2*cosx^3*sin x cosx^2)+(2sinx^2*cosx sinx^2*sinx^2) distribution
(cosx^2)^2
Is this right so far?
For #3,
sec^2(x) - tan^2(x) = 1.
the rest is easy.
ChaoticLlama said:
For #3,
the rest is easy.
That is indeed a quicker way of doing the question (I can't believe I didn't notice that!) cd246, this comes about from the identity sin^2x+cos^2x=1, and greatly simplifies the work needed.
I think I get what u 2 are saying... since sec^2-tan^2 equals 1, it would be 1+cosx, take the derivative and I get -sinx?
Yup, that's correct.
  • · Replies 40 ·
